LawMate CM-SG10 Glasses Camera Logo
A
Anonymous Posted on Mar 27, 2013
How do I get the mic to work on my LawMate CM-SG10 Glasses Camera?
How do i update the firmware and is this may be the cause of the USB b not recognizing any memory sticks that we've tried?
usb b is for streaming digital media,not memory sticks,
  • High-power dual DSP engine with improved digital effects and output processing including Feedback Ferret®, 28-band GEQ/5-band PEQ, delay and limiter
  • USB 2.0 "A" connection to record directly to or playback from memory stick
  • USB 2.0 "B" connection for streaming digital out
  • 3-band EQ with sweepable mid-frequency and variable low cut filters
  • 2 stereo channels with dual mic/line inputs
  • 48 volt phantom power
  • 6 Aux sends
  • 4 subgroups
  • 100mm faders
  • Double the processing power of the original FX Series
  • All new switching power supply design is more efficient than the original
  • Silencerâ„¢ mic preamp XLR inputs
  • Weight Packed: 45.00 lb(20.412 kg)
  • Width Packed: 25"(63.5 cm)
  • Height Packed: 36"(91.44 cm)
  • Depth Packed: 11.5"(29.21 cm
Yes I have the lawmate the bar in the middle went nutts does this mean there is hidden camera in my house
It means you're paranoid, but just because you're paranoid it doesn't mean they're not watching you.
Dec 31, 2014 • Cameras
LawMate PV-AC30 manual
To set the time / date stamp you'll need your remote control and you'll need to hook it to a TV with AV inputs. Be sure to correctly select the AV input the camera is plugged into. This is the most overlooked step that causes a lot of users frustration.
I've attached a YouTube video on how to accomplish the time/date setting.
I am seeking a replacement LCD screen for my Lawmate PV900 anyone know where to get one have searched but no luck
You will need the serial number from rear of screen or on ribbon connector
Then google it that will point you in the right direction
Is there a patch to help me install a webcam with mic # 25-157 for Windows 7?
Try using it in Compatibility Mode with earlier webcam software installed.
Right click on the webcam desktop icon or the file in All Programs
Select Properties and Compatibility tab
Check the box for CM
Select the OS
Apply OK
Paid for spy camera veido recording glasses they where shipped by lightinthebox. the glasses do not work can not get intoucn with anyone to see if I can get another pair that work. I paid for the glasses...
Try contacting the company or site you bought the glasses from, maybe they could send you another one. I don't think this has to do with paypal.
Regards
I want to know what brand of microphone to buy
It is the same mic. The singer's sound technicians just removed the mic from the crown headset and put it on a headset custom made to the singers head. This way it holds up more to the dancing and it is less complicated to put on.
It's not really a problem but a question on a microphone I would like to buy. I have a CM-311A headset but it's uncomfortable. There's another microphone out there that is similar to it except there is not...
There are numerous headset mics. Most feed into a bodypack the singer wears, which can be wired or wireless. It has the batteries required for phantom power, etc.  See what kind of a plug is on your existing mic. Probably a mini-xlr. You should be able to use any mnini-xlr mic with your rig. Go to your music store with your old mic and ask to see and try on other models. If the plugs are the same, the mics should be inter-changeable.
Top LawMate Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a LawMate Video Camera Expert? Answer questions, earn points and help others
