Before i buy the blank discs, i need to know which discs to buy, Thanks
The LG BD390 should read DVD+/-r if they are finalized. he same is true of DVD-rw discs. However, a lot depends on the burner and software you use for the burn. This unit will only support video mode, VR mode and AVHCD formats. It will also support DVD+R DL discs.
A lot depends on the movie and audio file codecs that you use to burn the disc. For a complete list of discs that are supported, see the manual. It's available here: http://www.lg.com/us/support-product/lg-BD390# .
I hope this helps. Please add a comment with the software and hardware that you are using to convert and burn your video for additional help.
SOURCE: Can't play a burned dvd disc on philips dvp 3120
You might have created a data cd, dvd player normally don't support data cd. If that is not the case then you the file format is not support by your dvd player.
You would have to search for a software to convert the file to the format supported by your dvd player. and write it on the disc again.
SOURCE: How to unlock code to make my LG BD-390 region
Ha.... Found the soultion.
The fix is the same as fr LG 5931.
I.e. download a small file and burnit with e.g. ultraiso on a DVD-R.
Boot yr LG BD370 or 390 with the DVD in the reader - it will flicker some numbers on the Display and then say Region 0.
You get the file here:
http://www.multi-region.net/lg
Worked like a charm :)
SOURCE: LG BD-350C
If you mean to play DVD’s that you may have purchased in another country the see below
For that you need to do a Google for "mymodel region free" or "region free hack"
Not all DVD players are capable of this often very simple modification that many manufacturers build into DVD player. (Usually just involves the remote control and a combination of keys)
Your search will turn up a lot of sharks that want money for the hack (fix)
IGNORE THEM
There are a lot of sites where the information is free.
If after opening up the region free parameter you still have issues and you still want to play your dvd's from around the world you might want to consider another make or model
I am STILL (lauren) unsure of FIXYA's policy on this topic and am awaiting further clarification on the issue with regards to handing out these codes as this is not HACKING in the same sense as pirate software etc. it is just enabling an extra feature that the manufacturer provided.
I would prefer not to get my @ss kicked. That is why I can only give you the search terms rather than site links or specific information
SOURCE: LG DVB T HDD/DVD 197 won't play dvd's want error
http://www.scribd.com/doc/13204064/Lg-Dvbt-HddDvd-Recorder-Dbrh190197198199
Above is the manual for your dvd.
What we need to is eliminate first of all the discs that you can`t play etc finalised, region code.
Check through the manual.
SOURCE: Why is it that my LG BD 360 will play most bku-ray
I have the same problem with the same movie you need to connect the bluray player to your modem and update the bluray to be able to watch newer blurays
http://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
Active ISO Burner will allow you to burn an ISO image file to CD-R, CD-RW, DVD-R, DVD+R, DVD+R DL(Dual Layer), DVD-RW and DVD+RW (including double layer, DL). Active@ ISO Burner software accepts command line parameters to automate ISO images burning process.
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files. Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner. Build and burn ISO files on the fly and compile all kinds of audio, video, and data CDs and DVDs from any kind of file (MP3, WAV, AVI, MPEG, DIVX, XVID). Instant CD & DVD Burner supports all major drives including CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
there are plenty of free burning software programs on the internet
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
