Question about Pride Jazzy Select 6 Indoor Power Wheelchair
Jazzy select 6 i have new batteries and new charger and it's still not charging
Posted by Earl Struchen on
Tigre Noir
    Sergeant:
  • 317 Answers
Check fuse or circuit breaker, connections, power cable....
Posted on May 17, 2013
5 Related Answers
mas Didiet
Reviditta Harmawan
  • 17 Answers
SOURCE: battery wont take a charge
How long you using this battery? Tighten your cable battery terminal and charger connector.
Regards,
mas Didiet
Posted on Nov 13, 2008
oregoon
  • 175 Answers
SOURCE: jazzy 1113 will not charge,
Most likely your charge isn't charging properly. You need a multimeter to test the voltage at the joystick. In the 3-pin femal connector measure the voltage across the two horizontal terminals. It should read about 24 volts. Now plug it into the charger and see if the voltage increases, if not, charger needs to be replaced. You can get one that plugs into the joystick on ebay a lot cheaper than going to the mfgr. about $50.00 or so. Even if the lights are blinking, it may not be putting out sufficient voltage to bring the batteries up.
Posted on Jan 08, 2010
Anonymous
  • 5 Answers
SOURCE: i need the pinout of the jazzy 1103 ultra battery
The Output voltage 24 - 29v ,Usually 27v. (And 4 Amps)
The Pin arrangement is Negative to the Left, Inhibit in the Middle, And Positive to the Right Assuming your looking into the plug itself from the front.
Always check with a Voltmeter first though because there are some chargers with the Opposite Pin Arrangement.
Posted on Jan 28, 2010
lennieg2000
  • 692 Answers
SOURCE: jazzy select hasnt been charged over a long period
Virginia sorry no. Your charger cannot pickup low batteries and charge them. You will have to purchase 2 new U1 batteries. If Medicare purchased your chair then they will pay for most of the cost of new batteries. If you bought the chair then I would look for a battery warehouse type store or an Interstate battery store and buy them there they would be somewhat cheaper than buying them from a provider. Hope this helps you
Posted on Sep 11, 2010
douglass smith
SOURCE: I have a Jazzy 1113 powerchair and the on board
my chair jazzy 1113 ats won't move.all the lights are flashing and the batteries are fully charged why are they flasng
Posted on Apr 28, 2011
What is the voltage and amperage that i would use to charge my jazzy select elite it did not come with charger
24 volt - 3 amp
Buy one SPECIFICALLY for it.
Jazzy Select Elite Parts - Jazzy Parts - All Mobility Brands - Mobility ...
https://www.monsterscooterparts.com/mobility/mobility-brands/jazzy/jazzy-select-elite
Items 1 - 72 of 72 - Order the Jazzy Select Elite Parts from Monster Scooter Parts, and know you ... Battery Charger Power Cord (IEC C13) for Mobility Scooters and ...
Amazon.com : 24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger ...
https://www.amazon.com/Jazzy-Select-Scooter-Battery-Charger/dp/B00CIZ1GW6 Rating: 4.5 - ‎42 reviews
Amazon.com : 24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger : General Use Batteries : Sports & Outdoors.
Pride Jazzy Select Elite and Jazzy Elite Battery Charger
https://atozwheelchairs.com/pride-jazzy-select-elite-and-jazzy-elite-battery-charger.html The Jazzy Select Elite and Jazzy Elite 6 Battery Charger is compatible with models with serial numbers beginning with JB3. It is an offboard charger that fully ...
Jazzy Select Elite Replacement Parts ' Battery Charger » Charger ...
https://www.southwestmedical.com > Replacement Parts > Pride Mobility
Battery Charger » Charger Assembly - Off-board, For S/n Begin With Jc1 replacement parts for the Jazzy Select Elite.
Pride Mobility Jazzy Select Elite Wheelchair and Mobility Chargers at ...
https://www.batteriesplus.com > Chargers > Wheelchair and Mobility > Pride Mobility Pride Mobility Jazzy Select Elite Wheelchair and Mobility Chargers from Batteries Plus Bulbs. Deep cycle chargers for electric power wheelchair and personal ...
Jazzy Select Elite and Jazzy Elite 6 Battery Charger - Care Motion
https://caremotion.com/.../pride-jazzy-select-elite-and-jazzy-elite-6-battery-charger US$105.00 - ‎In stock
A 24V 3AMP charger for for Pride Mobility Jazzy Select Elite and Jazzy Elite 6 powerchairs.
jazzy select elite charger Google Search
Aug 02, 2018 | Elite Health & Beauty
What batteries do I need for a jazzy select6 pride
information and batteries for sale.
info
Jazzy Select 6 - Specifications, Owner's Manual, Features & Benefits
www.pridemobility.com > Jazzy Power Chairs > Models
  1. Cached
  2. Similar
In-line motor technology for increased efficiency, torque and range. Built with ease of service in mind. Easy side access batteries. Tool-less front panel access to ...
[PDF]Jazzy Select Series - Pride Mobility
www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_select_series_om.pdf
  1. Cached
  2. Similar
6 www.pridemobility.com. Jazzy Select Series. II. SAFETY. Do not connect an extension cord to the AC/DC converter or the battery charger. Removal of ... Batteries for Sale
Pride Mobility Jazzy Select 6 Ultra Wheelchair and Mobility Batteries at ...
https://www.batteriesplus.com > Batteries > Wheelchair and Mobility > Pride Mobility
  1. Cached
  2. Similar
If you rely on a Pride Mobility Jazzy Select 6 Ultra powered wheelchair or personal mobility scooter to get around, Batteries Plus Bulbs can help you find the ...
Pride Jazzy Select 6 Power Chair from Pride Mobility ' 1800wheelchair ...
www.1800wheelchair.ca > Brand Showcase > Pride Mobility > Pride Powerchairs
  1. Cached
The Jazzy Select 6 Power Wheelchair from Pride Mobility is the ultimate ... Easy side access batteries; Full-length, flip-up armrests; Solid flat-free tires; Foot ...
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca ...
https://www.amazon.ca/Jazzy-Select-Scooter-Battery-Charger/dp/B00CIZ1GW6
  1. Cached
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca: Sports & Outdoors.
Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery
https://www.amazon.com/Mobility-Jazzy-Select-Wheelchair-Battery/dp/B009DKGCC8
  1. Cached
Rating: 5 - ‎1 review Buy Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery - This is an AJC Brand® Replacement on Amazon.com ? FREE SHIPPING on qualified orders.
ALL THE INFO HERE BELOW
Google
Nov 24, 2016 | Pride Health & Beauty
I am new at this i plug in c harger and only powre light comes on, is it charging or is the chatge light supposed to come on?and how long does it need to charge a jazzy select?
If your charger has a red and a green led on it when the green led lights the battery is charged. If you use it a lot during the day it may take 8 to 10 hrs or more to fully charge the batteries
Jan 11, 2014 | Pride Jazzy Select 6 Indoor Power...
Power light is on the charger but no movement from the jazzy select chair
You have to disconnect the charger in order for the chair to move. It automatically removes power from the controller while the batteries charge.
Jan 08, 2014 | Pride Jazzy Select 6 Indoor Power...
After charging my wife's Jazzy Select 6, all lights come on after power up. However, when the scooter runs for just a few minutes, it drops to 4 lights on and then goes to 3 lights not too long a
hi, well that sounds like the batteries have called it a day,
If possible try another charger because sometimes the problem can be created by the charger not charging properly or the problem with the batteries being made worse by a dodgy charger.
Regards
GeWiz.
Mar 02, 2013 | Pride Jazzy Select 6
My jazzy is used but i bought new batteries for it but the key pad will only cut on when the charger is attached. and wont cut on at all with out the charger.
super hmmm new batteries? well I would check the battery connections because you should be getting power to the joystick. The charger is providing power thru your joystick to be able to turn it on. Now when you plug in the charger are you getting any movement on the meter at the rear of the chair? If not but staying at zero then the charger is not charging the batteries and your batteries are not hooked up correctly. You will have to remove the seat and cover over the base to have access to the batteries check all the connections and make sure that if the plugs are colored that the red and white plug is plugged into the red and white plug going to the front of the chair and that the black and white plug is plugged into the black and white plug going to the front of the chair. If the wiring is ok then get a meter and read the voltage across each battery they should read 13+ volts fully charged. Plug in the charger and read the voltage at the batteries again if charging then you should read 16+ volts. If the voltage doesn't change then the charger isn't working correctly and if reading a good voltage then the batteries are bad and need to be replaced. Hope this helps
Apr 17, 2011 | Pride Jazzy Select 6 Indoor Power...
How long does it take to charge jazzy select gt
Mike it depends on the charger and how discharged the batteries are. But if you get into the habit of charging it overnite when you get up in the morning it should be good to go. A 3 amp charger will take longer to charge than a 4 amp or 5 amp. Now if you are charging overnite and still don't get a full charge then you could have battery problems ie one weak battery causing the chair not to get fully charged or it could be the charger but if the charger has been doing ok in the recent past then I would have to suspect the batteries Hope this helps
Feb 19, 2011 | Pride Jazzy Select 6 Indoor Power...
Jazzy select hasnt been charged over a long period and now batteries are not charging manuel says they may not charge to call provider what will be done can they be charged again?
Sep 11, 2010 | Pride Jazzy Select 6 Indoor Power...
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller...
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
Aug 26, 2010 | Pride Jazzy Select 6 Indoor Power...
Jazzy Select 6 Indoor Power Wheelchair: how to charge...
The Jazzy Select 6 requires an off-board charger. Plug the charger into a grounded outlet; preferably one that doesn't have other large loads on the circuit like refrigerator, freezer, microwave, etc. The male 3-prong XLR connector coming off the other end of the charger plugs into a female XLR connector which is on the joystick control's bottom-rear. Charge it overnight after each days use, and at least once each month overnight. You should get 2-4 hours of use from the chair at top speed with a 200 pound driver, depending on terrain and climate. If it isn't holding a charge, you will probably need two new U-1 type gel sealed batteries that run about $120.00 or so each. Make sure you test the old batteries first at a knowledgeable battery shop. These are deep cycle batteries and require a special testing. If the batteries are good, then your charger isn't charging. Search EBay or other online sites for a wheelchair charger in the 4-6 amp range. They can be found for about $45.00 or so. Pride will charge you a lot more.
May 18, 2010 | Pride Jazzy Select 6 Indoor Power...
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
584 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
