My monitor has started flickering after I turn it off for a period of time. It was just flickering a couple time but the time it takes to stop is getting longer and longer. I have been leaving the monitor on to keep from facing the issue. But it gets shut off every now and then. I would say it's the back light. Am I also looking at capacitors in the cold cathode backlight circuit?
If it's not under warranty, buy a new one from newegg dot com.
With a new one costing $270.00 I'm pretty sure I can repair an otherwise good monitor for a fraction of that. I'll just tear into it and see what makes it tick....
Are you joking or have no clue in life, this junk is 14ms, it's not LED backlight, NO HDMI,, it's old, 270.00 your hilarious , you can buy it right from junk viewsonic for 239.00. Why would anyone buy this outdated junk. A real monitor that's 24", has a 4ms, LED backlight, HDMI, is 160.00 NEW. 270.00 ROLOLLMAO
I may get thrown off but so be it. Pardon me for being so stupid to think a site called "Fixya" would be asking for anything but how to fix something "Duh" You smartass. Since I'm not quite the keyboard warrior you are, I use my IPS monitor for photoshop and the IPS monitors cost a bit more than your TN POS. Why did you even waste your time being a smartass when you obviously are so superior?
SOURCE: I have a VeiwSonic Monitor model VA712b that went blank.
sell it.. the product and sevice from viewsonic in my opinon sucks nothing but problems tv less then a year old want to ship it back and forth to fix it piece of s**t
SOURCE: Monitor only works for short period of time
it's internal..the video card/board inside may be weakening, with a thermal cut out that is built in, just for this purpose.
how long you had that one, and is it under warranty?
SOURCE: Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
SOURCE: LCD screen went blank
The Viewsonic VX2235WM has a known issue with the power supply going
out. The flashing power light or not turning on is the classic symptoms
of this issue. Check out our web site at: www.ccl-la.com. We have a
step by step repair guide posted that will guide to doing the repair
yourself. It involves changing a few capacitors on the power supply. If
you can solder then you should be able to do the repair yourself. If
you don't want to do the repair we do offer a repair service for $35
plus return shipping. If you have any additional questions just let us
know at: [email protected]
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
It does look like the inverer may be going bad. how many CCFL's does the VP2365wb monitor have? I would like to order the parts before tearing into it.
