Question about Briggs & Stratton Garden
My lawn mower starts but stopsin a few seconds
Posted by Latonya Robinson on
rlev_7
    New Friend:
  • 47 Answers
U have to clean carberator very easy take off bowl
Posted on Jun 20, 2014
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: Poulan 6.75 Lawn mower will not start
trouble shooting tips: oil is too full
fuel jet and float are plugged
spark plug lead wire may be damaged inside and needs to be replaced.
Posted on May 02, 2009
#1 Taper
Jim Parker
  • 1041 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
Anonymous
SOURCE: my craftsman rotory lawn mower 6.5 hp self
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
Posted on Aug 13, 2009
Phil Saunders
  • 110 Answers
SOURCE: lawn mower keeps dying
Remove gas cap. If mower now runs without stalling, your problem is the vent in the gas cap is blocked. Replace the cap. Common problem!
Posted on Sep 22, 2009
SOURCE: lawn mower will start when primed but will only run for few secon
It starts because of excess fuel from priming. It usually then gets it fuel from main jet in carb.
You need to find the main jet and run a fine piece of sturdy wire through it. That will restore fuel flow so your mower can continue running after the priming fuel is gone.
This is a good thing to learn. Main jets tend to clog a lot on mowers these days.
Posted on Jul 06, 2010
Mower wont start
spray carburetor cleaner (NOT STARTING FLUID) directly into carburetor if it runs for a few seconds if so carburetor needs cleaning and if not a rebuild done
Apr 05, 2014 | Husqvarna HU700F 160cc Gas 22-in 3-in-1...
Mower starts, and stops after a few seconds
could be a stuck fuel solenoid or clogged carburetor
Jun 06, 2013 | Parks Optical 13.5hp Briggs And Stratton...
Briggs & Stratton Starts but dies after few seconds Power Lawn Mowers
Add some fuel stabilizer to your gas, try starting again, if this doesn't work check your fuel line coming from the tank make sure it is not pluged if you have a fuel filter replace it with a new one.
Jul 25, 2012 | Briggs & Stratton Garden
Craftsman 6.75hp 22 mower starts for a few seconds and concks out
If the carbeurator is pitted or corroded in any way you need a new carbeurator
Steve's Small engine repair & Blade sharpening
Jacksonville. Fl
Feb 08, 2012 | Craftsman Garden
Lawn mower ran out of gas, after refilling it will start, run for a few seconds and cuts off. There is no primer button for this model.
It would be best to take this machine into a dealer like www.arcolawn.com and have the thermostat checked out. There were some early autochoke thermostats that would stick and cause problems.Best wishesJoewww.barter-joes.com
May 18, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
May 17, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Toro lawn mower
ethaanol in fuel...happens when gas sits too long...especially in a gas can in the garage
Apr 10, 2010 | Toro Lawn Mower With Toro Power Tools
Garden Logo
21 people viewed this question
Top Briggs & Stratton Garden Experts
John Trevino
JOHN LAPIER
dannydoesita
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
