Malber P21 Front Load Washer Logo
Question about Malber P21 Front Load Washer
I have a malber p21 easy. I want to reset the programme. We have tried to switch on and off however programme resumes from the last programme before switching off. Kindly advice.
Posted by denise_formo on
4 Related Answers
Anonymous
SOURCE: washer is jumping extremely only when spinning
I own a Malber WD1000, which is several years old. Recently, I had it transported a couple thousand miles across country, and due to the size of the pickup truck it was in, the machine had to lay on its side for the duration of the trip. Shortly afterward, the machine began making a loud banging noise during the spin cycle. Additionally, the door gasket had a "wrinkled" appearance.
After taking various panels off of the machine, I discovered the culprit. The insides of the machine (drum, etc), are more or less suspended inside the outer housing. This is accomplished by means of a pair of shock absorbers on the bottom, and a pair of large springs on top. This allows the inner workings to shake a little bit during the spin cycles, without transferring the vibrations to your floor. In my unit, one of the upper springs had come loose from the frame. The solution involved tipping the machine on its side, with the top cover off, and pulling the end of the spring back through the mounting hole in the frame, then finding a nut and bolt to occupy the additional space in the hole, so that the spring could not slip back out. Getting the end of the suspension spring properly seated again was no small task, but it solved the problem, and now the washer works just great again.
Long story short, I'd check to see if all the springs are in the proper place.
Posted on Apr 01, 2008
Anonymous
SOURCE: Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 washer on board a boat and it will not spin out the water. It is spinning but the water remains in the tub
Posted on Feb 19, 2009
Anonymous
SOURCE: I NEED A NEW HOSE
I'm a general contractor. I made up a new hose by using various couplings
and a speedy connector.
Posted on Jun 29, 2009
Anonymous
  • 80 Answers
SOURCE: my malber washing machine p21 will not turn on it is making a clicking sound but nothing else
It might be due to the switch problem or wire will be cutted for that which runs the engine... Check the wiring and switch on the machine..
Thanks
Posted on Apr 01, 2012
Where can I find parts for a Malber p21 washing machine? i have a briken door handle
notify manufacturer --an appliance shop--online search using make and model
1helpful
Where in florida can I get a malber p21 washer and get the dementions of it. I have one in NY and love it
A Malber P21 has the following dimensions:
Height:33 1/2"
Width:23 1/2"
Depth:20 7/8"
(From the AJ Madison Web Site)
The model is discontinued, though.
http://www.ajmadison.com/cgi-bin/ajmadison/P21.html
The current model is the P31.
It's an Italian model sold primarily in the New York area.
You may want to call Malber at 516.323.5299. or email [email protected]
My malber washing machine p21 will not turn on it is making a clicking sound but nothing else
Thanks
I NEED A NEW HOSE " Y - INTO ONE. WHERE CAN A GET ONE? I HAVE A MALBER P21.
2answers
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
1helpful
My washing machine won't fill with water
I have my washer connected to the kitchen sink. In order for it to fill I have to connect the hose to the faucet and turn it on, it is pain but that is the only way it will work for me. I hope this helps.
Water level not right
There is a water level switch on the machine. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you should find it easily. You can either clear any obstruction in the tube or replace the water-level switch (easy to do it). Good luck !
Top Malber Washing Machines Experts
David Shaub
Marvin
Marvin
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
