Have removed top cover and made sure that all hose lines are clear and all connectors as well. Tthere is a small motor with water pipe through the middle. Im unable to get water to go through this pipe. has springs and a small plastic ball inside. Any suggestions?
Hi Teri. You may want to have one of our Authorized Service Centers inspect your machine.
Here'a a quick link to help you locate one in your area:
SOURCE: Dirt/Collection Tank Bissell Little Green
I had the same problem, so I took out the black stopper, and soaked the whole thing in bleach water for about an hour, then I took a hand full of " aquarium " rocks and put them inside the tank, and shook them inside using a bit of the same water and then got rid of the rocks,( the rocks worked as an scrubber ) .... it worked pretty good
SOURCE: bissell 7901 proheat service manual
I took apart the cleaner to clean the parts that were dirty and I can't seem to put the roller back in. Any suggestions
SOURCE: Bissell Rug Cleaner Model 1695
I think you have the same problem as me, If you lay the handle down and remove the tank you'll see a vacuum hose that runs from about the middle of the machine back towards and up into the handle. that hose probably has a hole in it. which is my problem also I can't get at the part of the hose that runs into the handle. I hope I could at least help you figure out what the problem was.
SOURCE: Bissell pro heat carpet cleaner clear cover removal
just lift it up probably suction holding it
SOURCE: Bissell Proheat only sprays for a few seconds.
When was the last time you changed the flat belt? Even if it isn't broken it could be so stretched out that when the brush hits the floor it slows or stops the pump from spraying. If its a new belt then and your sure there arent any clog's that usually means the pump is bad. Also if youve ever used anything other than bissell shampoo in the machine it could have ruined the pump as well.
