2005 Lincoln LS V8 Logo
Anonymous Posted on Mar 27, 2013
CD won't load into the 6 disc changer.
I only got this car about 3 weeks ago, today, I tried loading a cd into the 6 disc changer and it would not load, is there a trick to loading cd's?
S Type CD Changer 'NO DISC' message when cartridge is installed
common problem try doing a battery reset disconnect battery for about a minute or so if it does not work check the wiring to the unit and the fibre optic d2b connector the cd changer was not a reliable unit
try doing a battery reset ie. disconnect the neg terminal battery in the trunk/boot leave it 1 hour and reconnect if still not work then the changer is gone duff or the wiring/or the fibre optic d2b link has gone down
1helpful
1998 Isuzu Trooper won't charge battery. 3 alternators in the last year and a half and all get "burnt up" according to the mechanic. There is a 6 disc cd changer that doesnt work and makes odd noi
have you checked the wire that goes from alternator to the battery ,and see how many volts are going back to the battery. it maybe grounding off
My Ford Explorer 6 disc cd has 1 cd stuck in it and it won't eject, play or let me load other cd's. How do I get the cd out?
take the radio out and take it apart and move the sensor out of the way and take the CD out you might have to replace the CD sensor
1helpful
2answers
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
14helpful
3answers
Hi what does Error 03 mean?
My endeavor has done this error 3 a couple of times and the cd changer basically shuts off all lights and won't do anything. Someone on another solution page said to slide a credit card back and forth in the cd opening to fix the problem. I've done this both times and it has made the changer play again as if nothing had happened : )
7helpful
2answers
2007 nissan maxima will not load or eject CD's...or even play the
Hi, this is a common issue within car CD changers. the load motor go through lots of trauma during the life span that i usually 3 to 5 years. the load motor operates everything in the changer. it works the load tray and spinning of the disc as well. when this motor is out, the changer will be rendered useless. replacing the load motor will fix this issue or, you can just purchase a new changer and save a lot of money.
4helpful
2answers
2005 ford expediton 6 disc cd changer
06 expedition 6 cd player and having the same issues,,, Disconnect battery and all 6 cd are stuck inside. "Error cd" shows when pushing eject. Looked everywhere and nothing shows how to fix it. I dont want to buy another radio/cd player for something that ford should know and how to fix?
Top Lincoln Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
