4 gb
SOURCE: formatting a 4gb sandisk for a nokia 5200
is ur nokia capable of handling 4gb. pls see the specs.
this is a issue many a time.
SOURCE: Memory Stick Pro Duo 8GB on PsP
Two possibilities.
1. The firmware on your PSP is too old to recognise the 8GB (only recognises up to 4GB).
2. If firmware is up to date you have a fake memory stick (easy way to check is to check the info for the memory stick on your PSP if its says that MAGIC GATE is unknown rather than supported then it is fake.
The fake ones typically double compress the data so that it appears to have 8GB when in reality it does not.
SOURCE: Formatting errors on 2 memory cards - old 1gb & new 4gb micro sd sandisk
http://www.sdcard.org/consumers/formatter/eula/
Go here follow the instructions to get a formatter program
SOURCE: memory card not formatted
yeah it is definitely a virus, remove it with a updated virus remover.
SOURCE: cannot delete in transcend micro sd 2gb memory card.
hi if you look on one side of the disk you will see a little white switch ( very small ) move this in the opposite direction of where it is and that should sort you out....hope this helps please vote thanks
