Question about Yamaha Electrical Supplies
Yamaha EF 1200 has no spark Changed plug still no spark
Posted by Gerry Levasseur on
Robert Wooley
    Habit-Forming:
  • 178 Answers
I have a neighbot that seems to have this problem half the time he tries to start his. I turn the ignition switch on and then it works 'til next time. He drinks a little. You should also check the oil level as many of these have a low oil cutoff switch. If this all checks out, then it is most likely the ignition module.. Hope this helps,Robert
Posted on Mar 28, 2013
Engine is running rich, spark plug is black, spark arrestor is black, after only 2 tanks, do they have smaller jets for this carb
you need to alter the fuel mix. there is a fuel mix screw on the side of the carb. screw in for less fuel. then check on ldel loads on spark plug... then test on full load then check spark plug again. dont mix up the idle screw with the mix screw. should have a white film on idle speed and a slight red colour or full load. run for 10min at a time then check.
Jan 08, 2014 | Yamaha Ef2600 Generator/inverter...
No spark on number six
bad plug wire.. bad plug or plug is not correctly seated try using an old plug wire to see if you get a spark then
Sep 21, 2009 | 2007 Ford F
Yamaha ef 2400is starting
The manual contains a schematic which does not show a heat sensor. You need to narrow it down to a fuel or spark problem. The easiest to check is spark. If you do not have spark, it could be the plug, wire, oil level sensor, magneto, coil or TCI module. If you have spark, then it is likely a fuel problem. Open drain and see if fuel is getting to the bowl. If not, check tank, valve and lines. If yes, it must be the carburator. Good luck.
Jun 09, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Virago 750 starts but wont excelerate
could be an air flow problem or a semi blocked petrol filter.try changing air filters and fuel filter. if that doesn't work try dismantling the carb and cleaning iy out. i jus had a similer problem with my bandit 1200.
Apr 18, 2009 | 1994 Yamaha XV 535 Virago DX
Rpm
Normal idle for most bikes should be in the 1000 - 1200 range, but your manual should give you a more exact number. If you don't have a manual, now might be a good time to pick one up.
Nov 10, 2008 | 1994 Yamaha FZR 250 R
Electrical Supplies Logo
284 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Dan Horsefield
Dan Horsefield
Robert Wooley
Robert Wooley
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
