Question about Texas Instruments TI-30XA Calculator
1.009 to the 17 power and higher
My TI-30XA calculator doesn't have the y^x or any carat sign to help me raise a # to a higher power than 10. I only have 10^x, e^x, and x^3.
Posted by Karen on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
The TI-30Xa has a "y^x" key located just above the divide key. To calculate 1.009 to the 17th power, press 1 . 0 0 9 y^x 1 7 =
Posted on Mar 27, 2013
5 Related Answers
Patrick
  • 56 Answers
SOURCE: i need to use a texas instrument calculator TI-30xa for a problem using the power sign
look for a key that has this symbol ^ this is often called a carrot. it's somewhere in the middle and on the right. go 10^21
Posted on Feb 13, 2008
Anonymous
  • 43 Answers
SOURCE: TI-30XA user manual
Nope, there's a download online at TI's website but it's the same as the one that comes with the calculator.
Posted on Dec 31, 2008
k24674
  • 8092 Answers
SOURCE: how can i raise to a negative power on TI-30xa
Use the Y to the x key [Y^x]. To enter the negative exponent use the change sign key [+/-] not the regular minus - sign.
Hope it helps.
Posted on Sep 29, 2009
Anonymous
  • 30 Answers
SOURCE: simplifying fractions on the TI-30XA
Two ways:
1) hit the equal sign
2) hit 2nd and [d/c] (you can do this multiple times to see it as the most reduced improper fraction or as a mixed fraction)
  • 102366 Answers
SOURCE: Does the TI-30XA have a sign to raise the number
There's a key marked y^x (y-superscript-x) to raise a number to any power.
Posted on May 24, 2010
1helpful
How do i put a number to the 80 power on ti-30xa calculator
The y^x button is located along the right edge of the keyboard, just above the divide key.
1helpful
When I raise 6.022 to the 23 power on my calculator (TI-30XA) it says error
It should not, unless you entered it the wrong way. Use the key marked [^] or [X^y] or [Y^x].
It is none of my business but I think you are trying to type in Avogadro's number. If that is the case then you should use the [EE] key to enter the power of 10.
Type 6.022 [EE]23 (Notice that there is no 10 to enter; the EE key is a shortcut for [*10^ ] .)
1helpful
I am trying to raise 0.92 to the power of 10, I cannot find the button anywhere on my Texas Instruments TI-30XA calculator. There is no y^x button on my calculator, please help.
Use the (y to the x) button, just under the off button.
Enter 0.92 press (y to the x) and then enter 10 and =.
I hope this helps you out.
4helpful
Does the TI-30XA have a sign to raise the number to a power of 4 or 5?
2helpful
2answers
How do i find the negative log on a TI-30Xa
Ex: calculate -log(15.32)
  1. Calculate the log 15.32 [LOG] [=] result 1.185258765
  2. Then press the change sign key (-) result -1.185258765
You can also try 15.32 [LOG] (-) [=]. Try to veriufy it on your calculator.
Hope it helps
3helpful
How to use antilog?
As you well know the pH is the negative of the log in base 10 of the H+/H3O+ ion concentration. If we use [H+] to represent that concentration, then pH=-log[H+].
To obtain the [H+] you need to calculate the antilog. You write the definition in the form log[H+] =-pH and then calculate 10 to the power of each member. The equality remains valid as both members are treated similarly. Thus
10^( log[H+] ) = 10^(-pH)
Since raising 10 to a power is the inverse function of taking the log in base 10, 10^(log(x))=log(10^(x)) = x (they are inverse of one another), you are left with
[H+]=10^(-pH)
Your calculator has a function [10 to x] accessed by pressing the [2nd] function key. To use it you must enter the negative value of the pH, press the [2nd] function key then the [10 to x], then the = key to get the result (concentration)
Exemple: let the pH=5.5, what is the H+ concentration?
With [(-)] being the change sign key, then
[H+]:[ (-) ] 5.5 [2nd][10 to x] [=]
The result is 0.000003162 or 3.16 x 10^(-6)
Hope it helps.
1helpful
How can i raise to a negative power on TI-30xa
Hope it helps.
2helpful
How do you do this exponent?
If you mean 3 raised to the power 375, sequence is
y to the power x (under OFF key)
375
Answer is "error" because the result exceeds the 9.9999.... times 10 to the power 99 limit of the TI-30XA
3 to the power 209 is about as far as you can go....
2answers
I need to use a texas instrument calculator TI-30xa for a problem using the power sign
Texas Instruments TI-30XA Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
