Question about Worldwide 2002 Ford Focus ZX5 2.0L Alternator - 110 Amps
Sweet-Burning Smell when vent is on
When my car heats up, sometimes (and only when the heat or "vent" is turned on,) There is a sweet smell that blows through the vent, however if it runs long enough, it will develop into a burning smell. Any ideas on what it could be??
Posted by Alex Tompsett on
Robert Wooley
    Habit-Forming:
  • 178 Answers
I am quite certain you have a leak in the heater core and you are smelling the leaking antifreeze. Check the coolant level for loss and look under the car where the water from the airconditioner normally drips.
Hope this helps you, Robert
Posted on Mar 28, 2013
Smells like something is burning when turning on fan mostly when turning on heat. Also makes a gurgling noise. Can hear it and smell from interior of van
Check you coolant level(gurgling sound). A sweet smell is most likely a leaking heater core. Burning oil is valve cover gaskets.
Sep 03, 2016 | Cars & Trucks
Burning smell or smell stuck in the vent?
sweet smell from an electrical appliance is ozone cause fir high voltage discharge ( like the sweet smelling air after a lightning strike
take it in for a proper diagnosis
May 31, 2017 | Microwave Ovens
Sweet coolant smell windows get foogy from heat
The heater core more than likely is leaking.
May 13, 2013 | 1994 Oldsmobile Cutlass Supreme
When i start white smokes comes out why
mine does the same thing.. it is a sign that you are burning oil kiddo..either that or antifreeze is finding its way into the engine through a crack or bad gasket.. check for oil smell and moist soot at the tailpipe, or a sweet smell if antifreeze..now if its a steam like smoke..thats normal byproduct of the burning fuel and goes away once the exhaust pipes and muffler heat up enough to blow out all the condensate water...
Jan 30, 2013 | Cars & Trucks
Oil leak
Are you sure its oil or is it anti-freeze.If its anti-freeze you will have a sweet smell come thru the heater when its turn on.
Oct 31, 2012 | GMC Cars & Trucks
I have a 2002 hundai accent , drove car approx 15miles with radiator steaming to shop. replaced radiator. now needs o2 heat sensor and I!m smelling a sweet type coolant smell, but very little and its...
the sweet smell is the motor burning off the residual coolant on the components that got sprayed with coolant.if the car got overheated enough it may have damaged the head gasket and is now burning oil due to the over heating.or there is a mechanical problem due to the overheating(ring problem,valve problem,etc.)if its burning oil then it can cause an 02 problem as the sensor will get coated with what ever is coming out of the exhaust.the heat sensor is part of the 02 sensor that warms the sensor up so the computer will go into closed loop sooner and help with fuel mileage.
Apr 05, 2011 | 2002 Hyundai Accent
There is white smoke coming out the tailpipe no smell of antifreeze
If it doesn't smell like sweet then you most likely got a bad tank of gas. Just to be safe keep an eye on your engine temp. and coolant levels.
Mar 26, 2011 | 1993 Dodge Intrepid
Heater immediately fogs all windows and there is a sweet odor in the cab of 2003 Buick Rendezvous, defroster works fine, but will not clear the windows after heat is put on
Sounds like a possible heater core failure(hole in it) the smell indicates to me the coolant(anti-freeze) is leaking into the passenger compartment.
Check the carpet in front of the front passenger seat for moisture, this would confirm heater core leak.
Good luck !
Jan 28, 2010 | 2003 Buick Rendezvous
Heat gauge shows hot , have to add antifreeze although no leak
Very common fault is head gaskets.  causing coolant consumption and bubbles in radiator.  Run vehicle, have a friend accelerate once or twice hard, while you smell exhaust for sweet smell of burning coolant.
Dec 18, 2008 | 1997 Ford Taurus
Worldwide 2002 Ford Focus ZX5 2.0L Alternator - 110 Amps Logo
Top Worldwide Electrical Supplies Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
