I have An envelope tray, tray 1 and tray 2. When I want to print something from tray 2 it says to load paper in tray one and I have to punch buttons in order for it to print from tray 2. What I would LIKE is to have tray 2 as the default tray and only pull from tray one when I load it. This was all working until I had an authorized HP dealer come out and work on it...now it is FULLY messed ip.
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
SOURCE: HP laserjet p4014n
Check the media settings for your paper trays. Make sure they are set properly, also check the diver media settings. Is the problem happening with a specific print job? If it is check the page setup for that document.
SOURCE: change default paper tray HP LaserJet 9050
When you click Print then right click on your HP ptinter - click Properties - Paper Quality tab - click Paper source and select Tray 2 - Click OK - then OK to print.
You can change the paper type in Tray 2 into Tray 1 and vice versa to save going into Properties to change the Tray selection.
