Question about Konica Minolta bizhub Office Equipment & Supplies
Can't delete registered addresses from Bizhub C203
We have an old server address that we want taken off, and I want to be able to edit the "favorites" tab. Any ideas?
Posted by Stan on
koeone213
    New Friend:
  • 47 Answers
YOU HAVE TO GO ONLINE USING THE BROWSER AND THEN KNOWING THE MACHINES IP ADDRESS
1)INPUT THE MACHINES ADRESS AND YOU BE ABLE TO DELETE FROM THERE..
Posted on Mar 26, 2013
5 Related Answers
Anonymous
SOURCE: BIZhub C250
Many many Thanks, A.Koshelev.
Posted on Sep 17, 2007
Anonymous
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
Anonymous
SOURCE: Cannot scan to email Konica Minolta 250 Bizhub
To scan to email, Administrator email address must be set in the machine (any bogus email address will work too).
Also, email server address must be input as IP address if DNS or WINS is not running in LAN.
Posted on Mar 09, 2008
Anonymous
SOURCE: getting the ip address
To print out machine current ip address, go to utilities, user setting, printer setting, print reports, configuration.
Posted on Mar 23, 2008
Anonymous
SOURCE: Bizhub 250 scan to email error
Change your account information from external to internal, i.e. yourmaildomain.com to yourADdomain.local. Change on the scan account as well as the email addresses.
Posted on Dec 22, 2008
When trying to scan to email from Konica Minolta C203 we get an error message "From Address not set, unable to Transmit, please specify From Address" any ideas.
need to create a from address in the copier either bye at the op panel or thur pagescope look up a you tube video how to set up to scan to email with a bizhub c203 or any bizhub 3 series
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 21, 2013 | Konica Minolta Bizhub c203 Copier
Hi, Our Konica Minolta printer c203 with reserved dynamic ip address in dhcp (windows server 2008 r2) won't print. Should I assign a static ip address? Kevin
it will be easier to set the copier up with a static ip. then the server can find it easier. to do this go into admin mode and change it.
Sep 20, 2011 | Konica Minolta Bizhub c203 Copier
What software do i need to scan through a PC?
GO THOUGH WEB BROWSER ONLY THING YOU HAVE TO DO SET UP IP ADDRESS, DOWNLOAD DRIVER FROM KONICA/MINOLTA FOR BIZHUB C203 THEN WEB BROWSE TO SET UP SCANNER SOFTWARE ALREADY THERE.
Oct 21, 2010 | Konica Minolta Bizhub c203 Copier
Konica Minolta Bizhub c203 printer will print from all computers in our network, but has stopped scanning
where do u scan e mail or folder? if e mail your smtp server ip may have been deleted/changed if folder the path may have changed/deleted or password changed on the server/desktop
Apr 05, 2010 | Konica Minolta Bizhub c203 Copier
I have a bizhub C451 in the office but no operating manual: I can't remember how to: add email addresses to scan to and delete old email addresses from the address book
You can download the manuals free from the KM Website:
http://help.bt.konicaminolta.ca
Click on the "Knowledgebase" link.
Utility/Counter button
#1 Create One-Touch
from there make selections that apply (Address Book).
once in the area you can create, edit and delete the one-touches
Feb 08, 2010 | Konica Minolta bizhub C351 All-In-One...
I want to scan to a file on my server with my bizhub c350 I do not know how to do that.
You can create a scan to FTP one-touch.
log into the device by entering the IP address into your web browser.
From here you can create, edit and delete one-touchs of various types.
Dec 15, 2009 | Konica Minolta bizhub C351 All-In-One...
I used to be able to scan to email from my konica Minolta 252 biz hub. I now get a 'server connect error' and cant send to e mail. how do i resolve this? thanks, Steve
the email server address may have changed
touch the utility counter button the the administrator button
touch network setting
touch email setting
touch fwd button
check to see if the host address is correct for email server
or check the email one touch button settings
To edit a one-touch E-mail address:
1. Press utility/counter.
2. One touch user box registration.
3. Create one-touch destination.
4. Address book.
5. Email.
6. Select the E-mail address.
7. Edit.
8. Then edit the address
Sep 28, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
My old e-mail address keeps popping up
Click All programs
Click Windows Mail
Click Tools at the top
Click Accounts
Click MAIL
Click Properties
Click SERVERS
Here is where you can change your EMAIL servers
Jul 09, 2009 | Microsoft Windows Vista Home Premium...
Deleting names in the e-mail section
Utility button on panel
Chose: One Touch Registration
Then: Scan
Then: Address Book
Then: Email
from there you can edit create and delete email addresses.
Feb 19, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
207 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
