Computers & Internet Logo
Posted on Mar 26, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Samsung led monitor turn pink colour suddenly ,how to solve this problem
Francisco Mauricio G
Level 3:
Genius:
  • Master 1,551 Answers
  • Posted on Mar 26, 2013
Master
Level 3:
Genius:
Answers
1551
Questions
Helped
525139
Points
4192
Check the cable connector
5 Related Answers
Anonymous
  • Posted on Apr 04, 2008
SOURCE: A pink vertical line appears suddenly on the screen
i have a samsung 15inch monitor.which is only 6month old.giving blue vertical line along the right side of monitor (almost 2 inches from right side) how to remove it plz someone help me.my mail id is [email protected] you..
Anonymous
  • 242 Answers
  • Posted on Feb 24, 2010
SOURCE: MY MONITOR HAS TURNED PINK
what monitor you have LCD or the picturetube monitor?
If it is a Picturetube monitor, the blue/ yello/ green cathod might have lost.
If they are showing ok then you can adjust your Monitor Data Cable, if needed if may need to replaced. The major probablity here is showing as Data Supply Cable for Monitor needs to be changed, i could help more if i had more details about the problem.
Anonymous
  • 3 Answers
  • Posted on Apr 25, 2009
SOURCE: Monitor turns pink suddenly
Backlight/s on the way out.
Franklin Ramsey
  • 35 Answers
  • Posted on Jul 31, 2009
SOURCE: monitor turns pink
First I would check the end of the cable that plugs into the computer, if this has become loose, it can cause discoloration. If it isn't loose, unplug the cable and see if any of the pins have become bent on the inside. IF they have become bent, you can usually carefully use a pair of tweezers to slowly bend them straight again (be careful because if you aren't you could break the pin off). If your monitor has the ability to removed the VGA cable from the monitor, you might try replacing the cable (most CRT monitors do not support removing the VGA cable though). Lastly, as this is a CRT monitor, you might need to Degaus the monitor or the electron gun could be coming out of alignment. Most CRT Monitor's have degaus button (usually marked by a symbol of what kind of resembles a horseshoe) which if pressed will degaus the monitor. If your's doesn't have a degaus button, try searching through your menu for the degaus option by hitting the monitors menu button. To see if your electron gun is out of alignment, lightly tap the side of the monitor. If you see the color change, or the color returns to normal, your electron gun is out of alignment and will get worse over time. Buying a new monitor is usually the best option if this is the case.
fixyathing
jhun T
  • 341 Answers
  • Posted on Aug 16, 2009
SOURCE: my screan has lost white colour and now it displays pink colour.
check your video cable....this is a common problem when a certain pin in the connector is loose
Samsung sa850t monitor right half of screen is solid blue
I think your Display monitor cable damage, or may be your motherboard display cheap damage, or your display driver problem create.
First of all you check your display driver or reinstall driver. Sec think used external VGA card or check it. If not solved then your monitor display section damage. So contact good monitor technician.
Thanks..
Samsung syncmaster 2433bw , suddenly went out of colour. Tested it with a ps3 but I found a setting that shows me colour .. its the dynamic option under magic colour
Samsung Sync Master 2433BW has the brightness rectangule and monitor menu in one corner of my screen. How I disable/remove that rectangul?
Monitor turned pink
Video-cards generate "primary" colours (red, green, blue), and "mix" those colours to produce millions of "secondary" colours.
First, try replacing the "data' cable between the LCD and the video-card.
Second, if your LCD works correctly when connected to some other desktop or laptop computer, then the video-card in your computer is not working properly -- not sending one of the "primary" colours to the LCD. Replace the video-card.
2helpful
My monitor resolution colour is changed to pink.
Check the data-cable between the computer and the monitor, and try a different cable.
Or, try connecting the monitor to a different computer, to see if the video-card in your computer is not working correctly.
If necessary, replace the video-card.
Colours on your monitor are produced by "mixing" the 3 "primary" colours: red/green/blue in various proportions.
Or, if part of the monitor that produces one of those 3 primary colours has stopped working, then the resulting "mix" will have too much RED/PINK. Fix/replace the monitor.
1helpful
My screan has lost white colour and now it displays pink colour.
2answers
Overall pink cast and pink stipe at top of all images taken.
Never had that camera, however, had the same problem -- the pink stripe and pink cast. Turns out the lens cover was slightly cracked and not opening and closing properly. Thus -- the pink cast.
Sounds like a hardware problem. You should probably return it as soon as possible.
3helpful
7answers
Grand Canyon Tech
Grand Canyon Tech
