WE are using ACCPAC ERP 300 Day end process is not function and when open the ACCPAC window the following message found in the window " earlier processing was not completed", In addition day end processing is not function.
SOURCE: Accpac day end error
Okay what you need to do Is get the Hotfix for this software from the manufacturer of the software and they should send it to you. (You may want to check to see if you have it already). Again the hotfix is what you need in order to solve the problem.
RCF
SOURCE: SAGE ACCPAC ERP Datasource activating problem in C#.NET
Add reference (ACCPAC.Advantage & ACCPAC.Advantage.Types);
using ACCPAC.Advantage;
private ACCPAC.Advantage.Session session;
private DBLink mDBLinkCmpRW;
session = new ACCPAC.Advantage.Session();
session.Init("", "XX", "XX1000", "55A");
session.Open("ADMIN", "ADMIN", "SAMINC", DateTime.Today, 0);
mDBLinkCmpRW = session.OpenDBLink(ACCPAC.Advantage.DBLinkType.Company, ACCPAC.Advantage.DBLinkFlags.ReadWrite);
This is how you can connect to DATABASE OF ACCPAC (55a)
Sheryar Nizar
http://www.sheryar.net
