Samsung SGH-A517 Cellular Phone Logo
A
Anonymous Posted on Mar 26, 2013
I want to unlock my phone SGH-A517 what is the phone lock?
I don't know what is the code
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Mar 26, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
2197
Points
14
Hi, You can get the accurate unlock code for a Samsung SGH-A517 from www.mobile-unlocker.com at affordable cost with free step by step unlocking instructions. good luck mate.
5 Related Answers
Anonymous
  • Posted on Oct 24, 2008
SOURCE: Samsung SGH-E250V subset lock code
Well, I try too much "unlocking codes" to my e250, and now "searching" then take "limited service"
I think must NSPRO service box to this procedure, because e250 - e250d - e250v serial type maybe not egal in the software versions.
!!!!!!!!!!!!WARNING!!!!!!!!!!!!!!!
You can make the Full eprom and custom eeprom reset E2P etc.. with this codes but I think this can demaging the built-in operation system.
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
*#8999*8378# Test Menu
*#4777*8665# GPSR Tool
*#8999*523# LCD Brightness
*#8999*377# Error Menu
*#8999*327# EEP Menu
*#8999*3825523# Don't Know.
*#8999*667# Debug Mode
*#92782# PhoneModel (Wap)
#*5737425# JAVA Mode
*#2255# Call List
*#232337# Bluetooth MAC Adress
*#5282837# Java Version
#*4773# Incremental Redundancy
#*7752# 8 PSK uplink capability bit
#*7785# Reset wakeup & RTK timer cariables/variables
#*1200# ????
#*7200# Tone Generator Mute
#*3888# BLUETOOTH Test mode
#*#8999*324# ??
#*7828# Task screen
#*5111# ??
#*#8377466# S/W Version & H/W Version
#*2562# Restarts Phone
#*2565# No Blocking? General Defense.
#*3353# General Defense, Code Erased.
#*3837# Phone Hangs on White screen
#*3849# Restarts Phone
#*3851# Restarts Phone
#*3876# Restarts Phone
#*7222# Operation Typ: (Class C GSM)
#*7224# !!! ERROR !!!
#*7252# Operation Typ: (Class B GPRS)
#*7271# CMD: (Not Available)
#*7274# CMD: (Not Available)
#*7337# Restarts Phone (Resets Wap Settings)
#*2787# CRTP ON/OFF
#*2886# AutoAnswer ON/OFF
#*3737# L1 AFC
#*5133# L1 HO Data
#*7288# GPRS Detached/Attached
#*7287# GPRS Attached
#*7666# White Screen
#*7693# Sleep Deactivate/Activate
#*7284# L1 HO Data
#*2256# Calibration info? (For CMD set DEBUGAUTONOMY in cihard.opt)
#*2286# Databattery
#*2527# GPRS switching set to (Class 4, 8, 9, 10)
#*2679# Copycat feature Activa/Deactivate
#*3940# External looptest 9600 bps
#*4263# Handsfree mode Activate/Deactivate
#*4700# Please use function 2637
#*7352# BVMC Reg value (LOW_SWTOFF, NOMINAL_SWTOFF)
#*2558# Time ON
#*3370# Same as 4700
#*3941# External looptest 115200 bps
#*5176# L1 Sleep
#*7462# SIM Phase
#*7983# Voltage/Freq
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*5187# L1C2G trace Activate/Deactivate
#*5376# DELETE ALL SMS!!!!
#*6837# Official Software Version: (0003000016000702)
#*7524# KCGPRS: (FF FF FF FF FF FF FF FF 07)
#*7562# LOCI GPRS: (FF FF FF FF FF FF FF FF FF FF FF FE FF 01)
#*2337# Permanent Registration Beep
#*2474# Charging Duration
#*2834# Audio Path (Handsfree)
#*3270# DCS Support Activate/Deactivate
#*3282# Data Activate/Deactivate
#*3476# EGSM Activate/Deactivate
#*3676# FORMAT FLASH VOLUME!!!
#*4760# GSM Activate/Deactivate
#*4864# White Screen
#*5171# L1P1
#*5172# L1P2
#*5173# L1P3
#*7326# Accessory
#*7683# Sleep variable
#*8465# Time in L1
#*2252# Current CAL
#*2836# AVDDSS Management Activate/Deactivate
#*3877# Dump of SPY trace
#*7728# RSAV
#*2677# Same as 4700
#*3797# Blinks 3D030300 in RED
#*3728# Time 2 Decod
#*3725# B4 last off
#*7372# Resetting the time to DPB variables
#*7732# Packet flow context bit Activate/Deactivate
#*6833# New uplink establishment Activate/Deactivate
#*3273# EGPRS multislot (Class 4, 8, 9, 10)
#*7722# RLC bitmap compression Activate/Deactivate
#*2351# Blinks 1347E201 in RED
#*4472# Hysteresis of serving cell: 3 dB
#*2775# Switch to 2 inner speaker
#*9270# Force WBS
#*7878# FirstStartup (0=NO, 1=YES)
#*3757# DSL UART speed set to (LOW, HIGH)
#*8726# Switches USBACM to Normal
#*8724# Switches USBACM to Generator mode
#*8727# Switches USBACM to Slink mode
#*8725# Switches USBACM to Loop-back mode
#*3838# Blinks 3D030300 in RED
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
#*22671# AMR REC START
#*22672# Stop AMR REC (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
#*22673# Pause REC
#*22674# Resume REC
#*22675# AMR Playback
#*22676# AMR Stop Play
#*22677# Pause Play
#*22678# Resume Play
#*77261# PCM Rec Req
#*77262# Stop PCM Rec
#*77263# PCM Playback
#*77264# PCM Stop Play
#*2872# CNT
*#8999*283# ???
#*22679# AMR Get Time
*288666# ???
*2886633# ???
*#8999*364# Watchdog ON/OFF
#*8370# Tfs4.0 Test 0
#*8371# Tfs4.0 Test 1
#*8372# Tfs4.0 Test 2
#*8373# Tfs4.0 Test 3
#*8374# Tfs4.0 Test 4
#*8375# Tfs4.0 Test 5
#*8376# Tfs4.0 Test 6
#*8377# Tfs4.0 Test 7
#*8378# Tfs4.0 Test 8
#*8379# Tfs4.0 Test 9
#837837# error=...
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
*2767*927# = E2P Wap Reset
*2767*226372# = E2P Camera Reset
*2767*688# Reset Mobile TV
#7263867# = RAM Dump (On or Off)
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
*#7465625# = Check the locks
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
#*22673# Pause REC
#*22674# Resume REC
#*22677# Pause Play
*#8999*427# WATCHDOG signal route setup
*2767*3855# = Full Reset (Caution every stored data will be deleted.)
*2767*2878# = Custom Reset
*2767*927# = Wap Reset
*2767*226372# = Camera Reset (deletes photos)
Samsung Secret Codes Part 3
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
Anonymous
  • 110 Answers
  • Posted on Feb 14, 2009
SOURCE: UNLOCK CODE FOR SGH-X460 MOBILE PHONE
first you enter *2767*2878#,once this has finished rebooting turn the phone off.Next a SIM card from a different service provider needs to be pushed half in,"Insert SIM" appears,enter *2767*3855#.now push the sim care fully.press *#7465625# for network lock.then press *7465625*77*00000000*00000000# ,your mobile now unlock.
Anonymous
  • Posted on Oct 09, 2009
SOURCE: Give some unlock codes for SGH-J700 phone
my sgh j700's bluetooth is not working
Andrew Portelli
  • 298 Answers
  • Posted on Nov 29, 2009
SOURCE: unlock code for samsung sgh-a517
http://www.cellcorner.com/xshp/unlock-phone-codes/samsung-a517-remote-unlock-by-code.html
Anonymous
  • Posted on Jun 14, 2010
SOURCE: i miss my phone lock code, how can unlock SGH-B130...
phone lock of sgh-b130s i did not know they password
2answers
Unlock samsung sgh-750
The unlock code is depend on your mobile phone's IMEI number(*#06# to know it). Don't use wrong unlock codes and make your phone permanently locked and not usable. You can ask the unlock code to your service provider but they will be more expensive. The best way to get the unlock code cheaper from the genuine unlocking sites like TheUnlockArena.com. I am recommending as i have used their code to unlock my phone successfully.
Free unlocked code for samsung gravity
The unlock code is depend on your mobile phone's IMEI number(*#06# to know it). Don't use wrong unlock codes and make your phone permanently locked and not usable. You can ask the unlock code to your service provider but they will be more expensive. The best way to get the unlock code cheaper from the genuine unlocking sites like TheUnlockSpot.com. I am recommending as i have used their code to unlock my phone successfully.
How do i get the unlock code for my sgh-a517
You can get the Unlock code for SAMSUNG SGH A517 at here Mobile-unlocker.com/samsung-sgh-a517/rs2wp9/ and unlock it from network lock.
Mar 10, 2012 • Cell Phones
3answers
How to unlock Samsung SGH C207
Try code from Online site..........
Sep 26, 2011 • Cell Phones
I forgot My samsung sgh-l870 unlock code and can no longer use a sim card.would u pls help me reset it back to 12345? its IMEI NO.354465020309685
There is no solution to reset your phone password back if your sim card already locked. The only option that you can do is call your network provider and request to unblock your sim card. But if you don't want to use that sim card network again, you can use samsung sgh l870 unlock code to unlock your samsung network and reset your phone. Samsung unlock code can you buy from third party sites but if you don't wanna use unlock code you can reflash your phone to nearest local mobile phone repair shop. Good luck!
1helpful
2answers
HOW CAN I UNLOCK SAMSUNG SGH-A777
To Unlock the samsung SGH A777 model Phone use the Unlock code ..get the Unlock code from here Onlinegsmunlock
and Unlock it from Network Lock...
Samsung SGH-A777 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Samsung SGH-A777 mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-A777 mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung SGH-A777 with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-A777 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-A777 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-A777.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-A777 is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-A777.
If method 2 does not work, you can try method 2 again but this time wi
Model Samsung SGH-M150 phone is locked (tried new sim card - sim card ok) Been give unlock code by Tesco mobile - doesn't work.
You must unlock your phone using samsung sgh-m150 unlock code for tesco network. This code can you get from tesco or you can buy from third party sites, but don't try to use free samsung unlock code from internet since most of them is a fake code and it will not work on your phone.
Phone luck
  • Power on without SIM
  • Type in #7465625*638*Unlock code# (8 digit unlock code*)
  • Device should say: “Network Lock Deactivated”
  • Phone may automatically reboot
  • *The 8 digit code can be obtained by calling the Mobile Operator Customer Care Department and given the representative the IMEI number. In exchange they will give you the Subsidy Unlock Code. Alternatively, you can go online and seek out a Subsidy Unlock site.
    To obtain the IMEI number press *#06# on your mobile device.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
