It appears that no identified service center exists in Singapore. You might want to try contacting Lanzar customer support directly for assistance: http://www.lanzar.com/ContactUs.aspx
So many manufacturers overrate their amplifiers. Nothing like Zed Audio from the 80's and early 90's. The old school amps like a Rockford Fosgate Punch 45HD, 75HD or 150HD will blow most subs apart now days. Check Ebay. I just shocked my teenage son and his friends yesterday with a Punch 75HD hooked up to his 15" Kickers. They were in awe. I have several old school amps for sale Autotek, Lanzar Optidrive, RF, Orion, Precision Power
the 50 C was used as a cheater amp back in the 90. You will be shocked by what this thing is capable of doing you can run an entire system subs mids and highs off of this 50 C. About 1300 watts
your output of the amplifier have been distorted. I suggest you take this to a reputable service technician that has experience with lanzar OptiDrive old school Rockford Fosgate or Orion. These technicians are hard to come by nowadays but they definitely are worth the money that they charge. I happen to be one of those such technicians.
Description
One of the oldest and most respected names in automotive sound is also one of the most consistent winners on the competition circuit. Lanzar offers a wide range of high performance subwoofers, from the pounding OptiDrive Series to the rugged MAX Series. The MAX12 dual-coil subwoofer offers high power handling, great bass response, an economical price, and a 3 year warranty. Specifications: *Power handling: 500 watts RMS/1000 watts peak *VCdia: 2" *Impedance: 4 ohms per coil *Magnet weight: 130 oz. *Fs: 33.6 *SPL: 88 dB 1W/1m *Vas: 3.19 cu. ft. *Qts: 0.47 *Xmax: 10mm *Dimensions: A: 12.09" B: 11.15" C: 6.42"
look in the yellow pages under electronics supplies wholesale.
that is a big capacitor. you may have to parallel 4 100uf @450 volts to make that value.
Have you tried replacing all of your fuses? If that does'nt work check your ground........ I would check all your connections also could be a connection shorting out causing your red light to come on.
when there are burnt traces on board if its only a few you can bypass them with jumpers then all circuitry has to be checked and tested befor you go any further,can go into more detail just drop me a line randall 574-220-0162
