How can I change the entry key code to a Genie 35674R Garage Door Opener UNIVERSAL "Wired" Keypad KEP-1?
I know this is an old post but in case anyone else has trouble with it...I just replaced this keypad for the 2nd time in 10 years, it just stops working after years of being exposed to the elements. I've changed the code several times but had a lot of trouble with it today in the new one. What finally worked for me when following the instructions to set the switch to "Set" inside the black box, type in your new code and then press and HOLD the star key for at least 5 seconds. Holding the star key down finally worked after multiple attempts to get it to work. Then set the switch in the black box to "Run" and the door should open after typing in your code and hitting *.
SOURCE: my garage door lurches while it is opening
If the alignment is true and rollers move with ease, you should not have any jerking motion. Unlock the door catch from the pulley line of the motor. The door should be FREE to lift by hand. With the door Free of the motor/line-pulley, lift by hand. Do so a number of times and see if it binds or is free to move up and down easily. If it binds, the alignment is off and needs adjustment. If it moves quite well, then the problem can be the door sensors. These are the two face to face sensing devices at the bottom of the metal guides on both sides. These sensors need to be horizontal and fixed to allow Line Of Site to operate correctly. Check both Alignments, Rails and Sensors.
