Question about Rotel Audio Players & Recorders
My rotel preamp wont turn on what is the power converter it has blown?
Is this part hard too fit and expensive
Posted by eli smith on
Grubhead
  • Rotel Master
  • 5,700 Answers
It's more likely to be a fuse that's gone. If so it could be caused by faulty device on the heat sink.
The only device that converts power is a Transformer. You can test this by simply putting a Volt meter on it's terminals. They are not hard to fit, however they have to be replaced by the same thing or one approved by Rotel.
Posted on Apr 02, 2013
Rotel RHB-10 amp not firing up anymore; protection light/cicuit not engaging
Check the rest of the power supply, for example the transformer if there is no power at all. If you are getting some indication of power, check the voltage regulator circuit.
Dec 19, 2015 | Rotel Audio Players & Recorders
Fuse for rotel amp for RB-870BX
IF THE FUSE YOU ARE PLACING IS THE SAME TYPE AS THE ORIGINAL YOUR AMP HAS A PROBLEM WHAT YOU MUST DO IS TO SLIGHTY INCREASE FUSE BY 100 MAMPS PER TIME IF IT IS IN THE TRANSFORMER CIRCUIT YOU CAN INCRESE IT BY 2 AMP MAX IF IT IS IN THE MOSFETS CIRCUIT YOU CAN INCRESE IT BY A MAXIMUM OF 500MAMP LET ME KNOW THE RESULTS
Mar 04, 2012 | Rotel Audio Players & Recorders
Rotel RTC-850 Preamp left channel is silent. After some interconnect swapping, I determined I have a problem with my Rotel preamp. When I play my CD input into the LEFT channel i get the...
Before we throw in the towel, turn it off and exercise every control a lot of times throughout its range, particularly the Tape Selectors. Sometimes oxides will develop on seldom used controls and their 'normally closed' contacts will not pass a signal.
Dec 25, 2010 | Rotel Audio Players & Recorders
Rotel processor bypass for Audio Research SP10
If I understand you, the 'sound' of the AR preamp is what you're trying to preserve. Presumably you're just running a phono through it as nothing else needs a preamp these days.
The multichannel inputs bypass all of the Rotel's processing except the volume. Use the Front L and R.
Mar 12, 2010 | Audio Players & Recorders
Rotel POWER AMPLIFIERS parts RB 870. The ON/OFF switch is broken - it will not turn off the amp. I have to pull the plug to turn it off. Where can I get a replacement part.
Power switches generally have to replaced by the same thing, due to safety standards.
I don't know if any of these firms stock Rotel parts, but you can give them a try. They are all online electronic spare part stockists: CPC, SEME, Willow Vale.
Two more appear to be trade only: Charles Hyde and Son, and Wizard.
Failing them contact Rotel, they might have the part or suggest the place to go.
Dec 03, 2009 | Audio Players & Recorders
I have a rotel RA - 820B x 3, that has stopped working.
Hi Nell. It is serious. Unless you are technically inclined, it needs to be checked out by qualified person. It will be fairly expensive to repair. Get an estimate.
Thanks
Paul
Jul 12, 2009 | Audio Players & Recorders
Rotel power amp
some amps have a switch to bridge them rather than wiring a bridge meaning output is mono check to see if yours has this switch if you do simply put back to stereo
May 20, 2009 | Rotel RMB-1095 Power Amplifier
Rotel PReamp, Can I directly Connect my powered speakers to the output
Based on your post, the pre-amp is doing its job. What might be the mismatch would be the powered speaker system plugged into the output of the Rotel. Depending on what the "powered speaker system" is, it might be that it is a low impedance such as those used in computers whereas the Rotel requires high impedance to be connected to its output. What could be tried is to connect a regular amp or receiver to the Rotel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Nakamichi AV-7 Receiver
Rotel RMB-1095 Power Amplifier Problem
Sounds like wiring problems. Unhook everything, then get owners manual for proper instruction
Apr 13, 2008 | Rotel RMB-1095 Power Amplifier
83 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
