The gas burners and broiler ignite fine but the oven doesn't heat up. I read where I should locate the shut off valve and open it up but cannot find it. The picture doesn't match up with mine. What do I do?
SOURCE: GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
SOURCE: JGBP33 BAKE IGNITOR
You did not post a complete model number, but this should help:
Take racks out of oven. Remove two screws at the very back of the oven bottom. Lift back side of bottom up and back a bit to remove oven floor. Remove flame spreader (one nut at center). ignitor is at the back left of burner, most likely a WB2X9154 (round style) ignitor. The entire burner can be removed rather easily at this point if you remove the two screws at the front and disconnect the ignitor wire (if you wish to have easier access to ignitor mounting screws.)
SOURCE: GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=RGB745BEAAD
SOURCE: broiler works, oven settings - no flame, no heat.
Hi, it sounds like the oven ignitor might be bad. Remove the floor panel inside the oven and you will see the ignitor attached to the burner assembly. Turn the oven on and see if it glows. You can test the connection for the ignitor and see if it gets 120V to it. The most common problem with the gas oven is the ignitor. Most of the time, the ignitor glows but is not strong enough to open the gas valve.
Please let me know if this was helpfull or if I can assist you further.
Thanks
Vic
SOURCE: xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
