Can i improve the performance by replacing the 5400 rpm drive with a 7200 rpm drive
Yes.
This is why people (Gamers usually), use harddrives that have a spindle speed of 10,000, or 15,000RPM.
Also why people use SSD harddrives. (Solid State Drive)
(Problem is those harddrives have a small storage capacity, in relation to harddrives that spin at a slower spindle speed.
One example; 1TB harddrive that has a spindle speed of 7,200RPM, compared to 10,000RPM harddrive with only 150GB )
To really improve the performance past that Bob, make sure you have the Ram Memory maxed out.
If the laptop for example, has 1GB of ram memory, and will support up to 4GB; this is the way to go.
Also, let's say the laptop uses DDR2 Sdram at 667MHz.
(PC2-5300 that is SO-DIMM)
But can support DDR2 Sdram at 800MegaHertz.
(PC2-6400 that is SO-DIMM)
It is BETTER to have MORE ram memory, than it is to have faster ram memory.
The first memory area for the Processor is the Cache.
(L1, and L2. Newer processors? L3)
This is a small memory area for the Processor.
Operates at same frequency rate ('Speed') as the Processor does.
Therefore it is the first memory area the Processor accesses.
Next in line is the Ram Memory.
Ram Memory typically operates at HALF, of the Processor's FSB.
(Front Side Bus)
Do not have enough ram memory? Then a small memory area is created on the harddrive. VIRTUAL memory.
Virtual memory is typically 1-1/2 times the ram memory.
More ram memory, faster computer.
Next memory area is the harddrive.
IDE (PATA) and SATA harddrives are mechanical.
As such they are way slow, in comparison to the frequency rate ('Speed'), that ram memory operates at, much less the Processor's cache.
SSD harddrive? Still doesn't operate as fast.
Want to speed your computer up even more?
Delete anything off of your harddrive, that you are not using.
(NOTHING Windows, though)
Programs, and applications.
Copy off personal documents.
Personal documents being photos, videos, music, and personal documents you have created, or downloaded.
The more stuff on a harddrive, the slower the computer.
Hit 50 percent full? You start to notice.
Hit 70 percent full? You REALLY start noticing now.
Also use a registry cleaner. (I use CCleaner. It's FREE, and works as well as paid for versions, plus better than some)
Cookies, and fragmented files take up room also.
Delete a program, photo, video, music, whatever; and bits of fragmented files are left over.
The more room on a harddrive, the faster the computer.
Remember back when the computer was new?
For additional questions please post in a Comment.
Regards,
joecoolvette
http://computer.howstuffworks.com/hard-disk.htm
SOURCE: Sony laptop hard drive options
In your laptop you cant upgrade your hard drive. Go for the web search for upgrade options , try it in sony web site please inform to fixya.com for any other porb.
SOURCE: gateway m-1625 laptop hard drive replacement
did you create a boot partition and format NTFS?
SOURCE: 1st Gen Macbook Pro Hard Drive Clicking
store.westerndigital.com or http://www.seagate.com/www/en-us/products/external/
SOURCE: Hello. i have the toshiba satellite a200-28n and
The maximum size hard disk you can install in your Toshiba depends upon the BIOS. The BIOS can support a hard disk up to a certain capacity. Check the specification of your model Toshiba to see the maximum hard drive it can support.
An alternative -
You can use an external USB hard drive and connect it to your Toshiba and not be restricted by the BIOS. You can use USB hard drive 500 Mb to more than 1 Tb.
The other advantage of using an external USB hard drive is you do not need to install Windows, the device drivers and your programs on the new hard drive.
SOURCE: I am trying to replace my HD in my Acer aspire
first ..Im not sure I understood how you installed windows on the new Hdd..but I sow that you didn't do it in the laptop ..
the correct way is to see if the laptop is seeing the Hdd..and to install the windows directly on the hard disk installed into the laptop ...by using boot-able installation disk with the operation system ..Cause if you install it on another device ..or other way ..it will not recognize the devices present on the laptop ..and most likely to give you a blue screen ..and errors like the one you just got ..
Another thing ..you have to go to bios settings ..advanced st-up ..most likely ..and see the Hdd in there ..and on its settings to disable the AHCI function ..cause if you do not have a disk with sata drivers ..the laptop with the AHci function enabled will not see the hard disk ..and this is the error and what it means ...basically it didnt found the boot device ..cause of this function probably enabled in bios..It is not hard to disable ..just press F2 on start up ..and go to BIOS settings ..and look for the feature that allow you to see the Hdd and disk drive ..and set them u ..it is either the device .or the advanced settings..Im not remembering exactly ..its the second or the 3rd feature..and in there you will find a function named...AHCI...this have to be disabled in order that the laptop to see and function with the HDD ..otherwise it will say that the HDD is missing or the boot device is not present ..
