Question about Stihl Ts 410 420 Cut Off Saw Decompression Grommet
Stihl ts 400 has stopped working and sounds rough when pulling the cord
Posted by ben longden on
Andrew White
  • Stihl Master
  • 2,239 Answers
Sounds bad, the only answer here is to pull the cylinder off and check the condition of the internals, if there is a lot of dust behind the filter and into the back of the carb the engine is going to be in need of rebuild.
Posted on Mar 29, 2013
4 Related Answers
Anonymous
  • 200 Answers
SOURCE: trying to start a stihl ts 400 disc cutter i
Try cleaning the plug and spray some starting fluid in the carb.Hope this helps and Thank You for asking!!!
Posted on Jul 19, 2010
Anonymous
SOURCE: hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Posted on Aug 03, 2010
snor38
Ron Sanders
  • 118 Answers
SOURCE: Stihl Demo saw 400 pulls
From [email protected] Hi kaqibso these saws are equipt with a decompression switch.It is located on the right side of the unit and has a red cap on it, pull out on it. Best of Luck......
Posted on Jul 01, 2011
jason webster
  • 3 Answers
SOURCE: Hi, my Stihl ts 400 blade runs at idle.I have tried adjusting the idle down as far as I can but it still turns.
seems that ur clutch is sticking.take recoil caseing of and check by turning blade by hand,if you feel the engine turning over,then your clutch drum is sticking,be sure to remove ur spark plug cap! it will be the bearing at the rear of the clutch drum,maybe a little oil and a few turns will help it free itself.hope this helps.
Posted on Jan 30, 2012
Carb settings for stihl ts 400
Standard settings: screw both in fully, unscrew H screw 1 full turn anticlockwise. unscrew the L screw 3/4 of a turn anticlockwise.
Aug 14, 2012 | Stihl Ts 400 Ts400 Carburetor Carb Rebuild...
Hi, My Stihl TS400 with 14"
Racing on a 2 cycle engine is usually a sign of a lean condition. It could be caused by a few different things including a bad crank seal or a torn intake manifold as some are made out of rubber. I would remove the cutter arm then pull the muffler to inspect the cylinder and piston. If they are scored it will be a costly repair.
Jul 14, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Stihl Demo saw 400 pulls with no compression
May 30, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
I have a stihl st400 disc cutter & I think the pull start needs cleaning, any advice?
compressed air works well. you really need a gun with a long skinny nozzle. for example
Jan 26, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Replace pull cord
i roadworks63. Pull off the right side cover to expose the recoil, remove the rest of the rope. Now rewindthe pully c.c.wise until it stops then release it just enoughto align the rope holes,use a C clamp to hold the pully from unwinding. Insert the rope enough to tie a knotHeat the knot to make it hard,now slowly let the pully re..turn or unwind tieon the handle. You are home free.
May 17, 2010 | Stihl Concrete Cutoff Saw Rewind Recoil...
Stihl Ts 410 420  Cut Off Saw Decompression Grommet Logo
444 people viewed this question
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Stihl Saw Expert? Answer questions, earn points and help others
