Question about Freezers
JLFFW2004 freezer warning buzzer was on, pressed reset for 4-5s and now display won't work, tried unplugging and switching back on but no joy, how can I reset the display unit.
Posted by kevin on
  • kevin Mar 25, 2013
    Sorry I should have also stated that neither the fridge or freezer work now, with the display not working nothing works. If I hold in the reset button for a while the display does light up with all the symbols Illuminated but nothing happens.No frost is apparent in the freezer or on doors.
NANDINI DUTTA MOU
    Master:
  • 551 Answers
You should be called the freezer expert now because your freeze gradually going to damaged.
Posted on Mar 26, 2013
5 Related Answers
Anonymous
  • 323 Answers
SOURCE: Kenmore Upright Freezer Alarm
1. You can hear the compressor running.
2. The temp setting you turn the thermostadt to starts and stops the compressor.
3. Look in your manual for a reset button and the location.
4. If you are familiar with a meter, grab the manual and check it it. But I doubt it is the resistance.
5. Sounds like a bad motor or low freon. If you have a lot of food in it, and the above didn't work, bite the bullet and call a repairman, although it sounds like much of the food is past saving if it is really defrosted.
Posted on May 12, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: freezer is buzzer is going off. we have unplugged
The buzzing is the compressor trying to start and not being able too...
Checkout this tip that I wrote about that problem...
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
heatman101
Posted on May 02, 2010
Russ South
  • 91 Answers
SOURCE: when I got home I
You dont have to reset it, you need to defrost it, the defrost element has failed and you have ice build up within the chiller plates, air cant pass through it due to the ice, I think you will find that food is starting to defrost and you will see a bit of ice on the back panel inside the freezer.
Defrost it for 2 days with door open, after that, should work fine for a week or so, very common problem.
Hope that helps, Russ
Posted on Jun 29, 2011
Sajjad Inamdar
  • 661 Answers
SOURCE: "Power" light off. Temp warning
Hi Dugga,
This seems to be a problem with the circuit board ,
This causes fault in it that does not allow the board to come back on or work properly sometimes if the power blinks off and back on.
You need to check if the part is under warranty , if it is , then get it replaced for free or you can buy a new board so that this problem is eradicated once for all.
This is not a new problem , there were many defective boards that were recalled by the company and replaced free of charge, probably you were left out.
Hope this helps ..:)
Posted on Aug 26, 2011
Anonymous
SOURCE: Kenmore freezer buzzer
I would need to model number to check if you have a on/off for you over temp alarm. That "Buzzer" is a over temp alarm. If you fridge uses a 9volt battery then you might need to replace the battery. Please post your model number.
Posted on Mar 14, 2013
I have an older model chest freezer. The alarm buzzer and light came on. I silenced the buzzer but the light is still on. The freezer is cold and still freezing well. Door is good and closed. It’s running...
Without a posted make and model number, it is hard to say. You need to unplug the unit from the power for a couple of minutes and then plug it back in to see if it resets
May 25, 2018 | Freezers
Buzzing noise ft
Warning buzzer. Unplug and try resetting system
Oct 05, 2013 | Magic Chef Chest Freezer MCCF5WBX
Freezer alarm
Hi Clair, thank you for allowing me to assist you.
When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Sep 06, 2013 | Electrolux Freezers
Frigidaire Freezer keeps making 3 beeping sounds then displays a 1
Hello Melinda, when the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board, wiring failure or faulty compressor since error code 1 typically indicates an issue with the compressor. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
I hope this information helps to some degree.
Jul 30, 2013 | Frigidaire Freezers
Mar 13, 2013 | Kenmore Freezers
My deep freezer wont freeze..it keeps beeping..what do i look for to find out how to fix it??
Hi monilvsjay - Typically when the freezer is beeping it indicates a warning of a possible malfunction or an unsafe temperature inside. The silence the buzzer, press the ALARM OFF button, however if you have already done so try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. The freezer could possibly be experiencing a communication problem with the temperature control/board or wiring failure.
Nov 10, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore elite upright freezer service manual mod# 253.28093800
There is a lock on the display. Try pressing standby button for 10 secs
Apr 14, 2012 | Kenmore Freezers
Temperature warning light came on. Removed
dear sir/madam
i think its tempretor sensor /thermostat problem please try to find thermostat needele and keep in right position , and check its tempretor satting if it,s need to reset please reset it . i hope after that it will working good. if not please try to contect your freezer maintanance perssonel for repair/reset your freezer .
hope answer the question.
thank you
please vote!
Jul 18, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I think problem its not with thetmostat but the compresor work but not correctly not have enought power to create pressure.
May 12, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
237 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
