Had our propane tank worked on last week. They turned everything off now it won't go back on
Check for a gas shut off inside the fridge cabinet as well. You may have to bleed all the air out of the lines before the fridge will get gas. either keep trying or run stove burners to make sure gas is working. Also look for debris inside the burn chamber near the thermocouple/pilot light.
I had rust fall from the exhaust tube and block the burner area. Cleaned it up and it works fine now.
SOURCE: I have a Norcold 2 way fridge. The propane will
It is possible that the switch is giving you fits. Easiest way to check is to find where the DC voltage goes to the circuit board. Put a meter across the connections and read the DC voltage.
A poor ground can also cause this as well, and is quite common. Remove the DC connections, and make sure that they are bright and shiny. Also make sure that the connections are tight, both in the wire, as well as any crimp connectors. Check for corrosion on crimp connectors in the sleeves, if possible.
Your 10second problem can also be attributed to another cause as well. The thermocouple electrode assembly is very sensitive to placement in the flame, as well as spacing of each "prong".
If you have a multimeter, also check the "AC" voltage as found on the DC supply. You should not have more than a few hundred millivolts of ripple (noise?) present. Very much more can cause erratic operation as well.
SOURCE: RV freezer cools, but fridge section doesn't
Sir,
To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant.
I suggest you to contact the service authority.
Thanks for contacting Fixya.
SOURCE: Norcold Model 682 problem
no these units run on 12 volt aswell check your fuses or and be sure u are getting atleast 10.5 volts to that fuse
SOURCE: norcold refrigerator igniter not generating a
Sounds like your ignition board is not working.
Aftermarket ones have a common automotive fuse.
Have a look at the following on line so you know what you are looking at in your unit.
Dinosaur electronice makes a UIB ( universal ignition board ) that will fit just about any fridge.
about $100 online. $250 where I tried to buy one at a rv place.
SOURCE: 1996 Komfort trailer, model 9182
The electrode that ignites the burner,also senses flame to keep burner going. Sounds like it's defective. I'd replace it, but take old one with you to match it up.
