Question about Mitsubishi WD-65731 65" HDTV
Bulbs keep blowing
I have owned the t.v. for almost six years and have had to replace the bulb 4 times. but recently i replaced the bulb a week and half ago andthe bulb blew after 1 week. i ordered another bulb and repaced it just this past friday,and this bulb blew sunday night. i dont belive i could have gotten 2 defective bulbs back to back. in the past the bulbs seem to last about a year to 18 months, but to go through 3 bulbs in 3 weeks i feel that there may be another problem with the t.v. im unable to detect.
Posted by Eric Benyon on
ZappaNut
  • Mitsubishi Master
  • 959 Answers
You may be touching the bulb (ampule) and leaving a fingerprint on it which creats a hot spot and blows the bulbs up prematurely.
Posted on Mar 25, 2013
5 Related Answers
coyotedave
  • 280 Answers
SOURCE: just replaced the lamp after 2 years. TV worked
Make sure that the lamp cage is seating well .. then make sure the door is closed properly. there is a door switch and if the door dont close right the switch may be telling the set the lamp is out.
Posted on Oct 23, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Posted on Apr 30, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: green diagonal lines across picture on Mitsubishi WD-52725 TV
If the lamp light turns red and the set wont power up put the V26 Power repair kit in and that should take care of it. The kit contains the capacitors and detailed instructions on CD
Posted on Jul 22, 2009
Anonymous
  • 115 Answers
SOURCE: I replaced my bulb on my wd65731 but screen still
Put the lamp door back on ..:) then rate me
Posted on Oct 04, 2009
Testimonial: "I figured this out last night on my own, but yes you are exactly right."
tvrepairbiz
Paul Bruno
  • 63 Answers
SOURCE: WD-57731 every 6mos bulb replacement
You need to make sure you have at least 6 to 8 inches of clearance behind the set. You may also need to replace the balast
Posted on Feb 15, 2010
Why my isuzu d max headlight keeps blowing
check for loose bulbs and dirty earth points. Bulbs blow because of power surges normally from bad connections and loose bulbs.
Dec 23, 2014 | Isuzu Cars & Trucks
Head light bulb on 1992 chevy silverado 1500 4x4 keeps blowing up
If you touch the bulb (glass ampule area) the oil from your skin will get in it (fingerprint) which will in turn creat a hot spot on the bulb and blow it up .
Mar 23, 2013 | Chevrolet Silverado 1500 Cars & Trucks
Light bulbs keep blowing fisher and paykal fridge only
Check the door switch for a loose wire or short.
Nov 03, 2012 | Refrigerators
My oven light bulb keeps blowing on my Whirlpool oven.
becoz of some problem that might be your oven is on for long time
Apr 10, 2010 | Ovens
Tv wont go on, power light keeps blinking red 6 times
I amhaving the same problem. Did you ever get an answer?
Apr 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Why does my fuse keep blowing for my tail lights in my 96 plymouth breeze ?Every time I put fuse in it cut the lights on the fuse blows?
The fuse keeps blowing out because there is a short circuit. Check the tailight sockets for corosion. Is there a tow package wiring installed?
Jul 26, 2009 | 1996 Plymouth Breeze
Headlight bulbs keep blowing out in 2004 Kia
THIS HAS GOT TO BE A KIA ISSUE!!! I've only had my kia a year and 4 months and have had to change both headlights TWICe possibly one side three times!!! AND every time the DEALER changes them NOT me soo its not like I am touching the bulb!!! I can't flipping get to the damn lights or I would change it on my own cause it cost me 35 bucks each time!!!!!!!!!!!!!! I'm FED up with changing these bulbs EVERY several months. Anyone have any suggestions on who we can connect about this....it MUSt be a kia issue!!! There is NO WAY this should be happening!!!
Jan 15, 2009 | 2004 Kia Sorento
Bulbs frequently burning out.
The bulbs last forever on my 240s, but they don't last on my '94 850 and '98 XC70. The dash bulbs are hard to fix and the radio bulbs are soldered in. One solution is to always keep the dash lights dimmed about 30% from full brightness, and don't leave the headlights on during daylight. I keep them on but need to replace at least one headlight bulb each year. You could also check the battery voltage with a simple voltmeter just to be sure the voltage regulator is within spec. If the charging voltage is too high, the battery life might also be shortened.
Jan 07, 2009 | 2001 Volvo S60
Mitsubishi WD-65731 65" HDTV Logo
690 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
