Question about Zoom R8 Digital Multi-Track Recorder, Interface, Controller, and Sampler Bundle with 10-Foot Instrument Cable, 10-Foot XLR Cable, Headphones, and Polishing Cloth
"no project" is shown on screen on my zoom r8
Posted by per cronholm on
1helpful
2answers
Why zoom g2 point blinking ?
There is damage/burnt at Transistor Q4 or Q3 or both. Usually followed by R8. Replace it.
Q3 = BC337 (SMD marked as 6C) NPN.
Q4 = BC327 (SMD marked as 5A/B/C/D) PNP.
R8 = 470 ohm (SMD marked as 471).
Will not zoom all the way
Hi Russell, Sounds like drive function problem. Almost like it is trying to over-travel. This is going to need service / repair before any damage is done.
Best Regards, Russell
Roland r8 has flashing green light
Are you using the correct AC adapter? An aftermarket unit will do this if the power is insufficient, or the polarity is wrong (- / +). If you're using an aftermarket unit, it may not be providing the right amount of Amps and Voltage to the unit; causing the display to blink. You can try this cord to help: http://www.powerpayless.com/ac-power-adapter-for-roland-r-8-r8-drum-machine.html
Jan 13, 2013 • Music
Projection is too close cuts the screen what do i do
have you tried zoom setting in the menu? wide, full , or zoom?
TV margins off screen.
your (Sat.Cable box is in zoom) or your tv is in zoom .
I have a 6 month old Ricoh R8 camera cracked screen
I would send camera away to be fixed since its only new let the profesionals replace it. tell them when you got it the screen was cracked . Up there for thinking, down there for dancing as they say
Hi, I have a problem. I have an MRS-8 and I was recording and wanted to do a new Project so I selected new Project003 (the other project was Project002) now I cant retrieve the old project. how can I go...
Here are the instruction to retrieve a previously saved project on the Zoom MRS-8.
1. From the main screen press the [SYSTEM/UTILITY] key in the display section.
2. Verify that "SYSTEM PROJECT" is shown and the press the [ENETR] key.
3. Use the LEFT and RIGHT cursor keys to select the operation you want (look for PROJECT SELECT).
4. Press the [ENTER] key when it says project select on the display.
5. You'll see the name of a project in the following format "PRJ002".
6. Turn the dial to select the desired project.
7. Press the [ENTER] key to load the project.
8. When loading completes the unit will return to the main screen.
Cheers,
bd.
SamsungLE26 R8 Picture Settings Problems
tv had reverted in to shop mode.I accessed the secret bmenu and restored the normal settings. Thanks
Zoom R8 Digital Multi-Track Recorder, Interface, Controller, and Sampler Bundle with 10-Foot Instrument Cable, 10-Foot XLR Cable, Headphones, and Polishing Cloth Logo
Top Zoom Audio Players & Recorders Experts
Ekse
Paul Bade
Muzahura Frank
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
