DC-1 code. switched the power off and back on, code gone. Do I need to follow up on the code?
Reset the error follow the steps. God bless you
QUESTION: DC-1 code. switched the power off and back on, code gone. Do I need to follow up on the code?
ANSWER: Probably not. Same thing happened to mine. No issues here. However, should it start happening on a regular basis, contact LifeSpan Service.
ERROR
CODE # 7
E7-
1) Alternative Elevation Motor
1)Cause:
Elevation Motor not moving Solution:Check
Elevation Motor connection
2)Cause:
Elevation Elevation Motor screw binding Solution:
Clean screw and lubricate
3)Cause:
Elevation Motor Motor out of Range Solution:
Check motor out of elevation
4)Cause:
E-Motor Potentiometer: Solution:
Replace Elevation Motor
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
On/Off switch Solution:
Test unit is turned on b)Cause:
Insufficient Power Source Solution:
Plug
dedicated120V, 20Amp Outlet
c)
Cause:
Line
Cord Damaged Solution:
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Doesn't Light Up: a)Cause:
Plug
c)
Cause: Line
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
However RUN the software calibration for diagnostic, troubleshooting and Fix it.
God bless you
