SOURCE: error in tally 7.2
hi
you have have tried ctrl+alt+r
plz copy your data any other folder and delete this file tr01296.500. and have retried ctrl+alt+r and rewrite this company
SOURCE: Perfect Focus not working
I know this post is old, but for others, I apparently pulled out the connector from the sensors to the CG module when I took the front panel off. The module is the silver box, third box from left.
Plugged it back in, and the perfect focus now works.
-dan
SOURCE: My DP-301u printserver of D-link worked perfectly
I have same problem and can't find solution. Site recomended not working. Printer allways offline. Firmware and other soft not healing. :(. Anyone help us.
SOURCE: i have dell model no
It sounds like a power failure.
If it is plugged into a surge protector, try resetting it. In the Dell manual, it says, "if the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist. Ensure that the voltage selection switch is set to match the AC power at your location (if applicable). Ensure that the processor power cable is securely connected to the system board (see page 73)."
There is another thread on FixYa that might be of some use: http://www.fixya.com/support/t274632-dell_gx150_power_light_flashing_orange.
Finally, I checked a Dell forum and found this discussion: http://en.community.dell.com/support-forums/desktop/f/3514/t/17794576.aspx.
If you do need to replace the power unit, I found a replacement part at http://www.discountelectronics.com/index.php?l=product_detail&p=2168.
If you are not comfortable replacing the part yourself, you can use a PC repair service, such as the Geek Squad. It might be worth getting a second opinion.
Thank you for using FixYa!
I'm an knowledgeable owner and have helped many owners across 4 different forums save their $1K machine at reasonable cost. If you want to DIY I will help at this forum........ Google this ""FAV6800A/FAV9800A Outer Tub bearing replacement"" read thru the post and see if this is for you or someone that can help you DIY the work..............Good Luck dh1200s
I ASK THIS QUESTION ABOUT ONE MONTH AGO AND BECAUSE NOBODY GIVE ME A SOLLUTION MY ONLY OPTION IS TO SOLVE THE PROBLEM MYSELF AND I DID IT.I HAVE CHANGED THREE CAPACITORS :47 microF ,50V;47 microF,50V AND 2,2 microF,50V AND IT COST ME A 9 DENARS OR 1/7 OF EURO.NOW TV STARTS PERFECTLY FOR 2 DAYS WITHOUT ANY PROBLEM .YESSSSS
