Tried checking power surge cord and usb, but everthing is connected and it still won't power on.
SOURCE: I run the hp laser jet p1005 setup cd on windows
Ok,right click on my computer > manage >divice manager >just check for yellow or red cross button and right click on that say update driver it will give you a wizzard go thruogh it, if it red cross just click on enable
SOURCE: my hp laser jet 3030 keeps reading 79 error power on power off
Try to perform a soft reset
1. Press MENU/ENTER.
2. Simultaneously press then release the * button and the # button to enter the Developer's
menu.
3. Press the < or > button until the message REINIT FFS appears on the second line of the
control-panel display.
4. Press MENU/ENTER.
5. The process takes approximately 2.5 minutes. During that time, the control-panel display
will change several times before returning to Ready.
6. When the Ready message appears on the control-panel display, press CANCEL to exit the
Developer's menu.
SOURCE: HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
SOURCE: HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
SOURCE: how to install HP laser jet M1522nf and connect my
How are you connecting this printer to your computer ? usb or network ?
If its network i would recommend you to make sure that the IP Address on the printer matches with the one set on the printer driver on the pc
Tryn reinstalling the software a detecting the printer automaticly
HP 3015MFP error 51.0
1.
The product has experienced an internal hardware error.
2.
Turn the power off and wait 30 seconds and turn the power back on.
3.
Check the cabling connections to the laser scanner assembly.
4.
Try connecting the product to a different power source or surge
protector.
5. If the error persists, replace the laser/scanner assembly.
