Yamaha RX-V473 5.1 Channel Network AV Receiver Logo
Question about Yamaha RX-V473 5.1 Channel Network AV Receiver
RX-V473 Internet connect
I have a new RX-V473. I want to listen to my local FM station on the Internet for clarity. I have a IMac, a Apple TV, and a Smart RG router Model SR300N supplied by my cable provider. The computor and router are in another room but I have already run a Cat5 cable from router to net the network jack on the reciever. That did not work. What is the best way to connect my reciever to the Internet.
5 Related Answers
Anonymous
  • 6966 Answers
SOURCE: Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 20, 2008
Anonymous
SOURCE: No audio after hooking up RX-V363 to TV monitor (from cable box )
The HDMI on the RX-v363 does not pass the audio.  You need to either connect an optical or digital cable from your audio source.  If it is a cable box or DVD player there should be audio outputs in addition to HDMI
Posted on Dec 31, 2008
Anonymous
SOURCE: I have a Yamaha Rx-v363
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Posted on Jan 04, 2009
Anonymous
  • 133 Answers
SOURCE: connect Airport Express to Yamaha RX- V659
Since you're using a standard mini jack to double RCA cable, it's safe to assume you'll be sending line level signal into your reciever, so i think any of these audio inputs will do: AUX, CD, DVD, MD, TV.
Also try the inputs on the front of the unit (i guess they are meant to be used with a video camera or similar but they are designed for line level signals so it should be ok if you decide to use them).
Anyway, keep the source signal at a moderate
level when you test any of the inputs and raise it to a suitable level after you're sure it is coming thru well.
Normally, the AUX input is suitable for any AUXilliary signal source that puts out a line level signal, but if it is already being used, you may use other free inputs.
If you use TAPE or PHONO inputs, you should keep the signal level from the source a bit lower since these inputs will amplify the signal a bit more (especially the phono input which works with signals that are lower in level than the line signal).
I hope this helps.
Regards
3rq8 (Triarcuate)
Posted on Sep 07, 2009
Marek Podmaka
  • 127 Answers
SOURCE: I plugged in my cable HDMI into my RX - V365
RX-V365 doesn't support HDMI audio. You need to connect the cable box also via spdif cable for audio to work. Look at the box if it uses optical spdif or coax spdif. If optical, you see that optical input on receiver is named DTV/CATV, so use also DTV HDMI for video. Coax spdif is named DVD, so in this case you will need to use DVD HDMI input.
Also you need to configure the inputs accordingly.
Posted on Mar 02, 2010
tip
How do I Attach my iPod to a Radio in a 2002 Miata
<p> <p>Apple's iPod is a great way to listen to your favorite music in private and comfortable. The transfer of this experience in the private confines of your Miata is a great way to enjoy your music while you drive. Apple recommends a variety of devices that you connect your iPod directly to your Miata radio. Attaching your iPod to the radio in his 2002 Miata is a task Hable accompli given the right materials and installation. <br /> <p><br /> <p>1. Buy a car adapter. Apple recommends a variety of products at a price range and power, the Monster iCar Play Wireless 800 FM Transmitter $ 79.95 Belkin Tune Cast Auto for Live for $ 69.95 in FM Transmitter Griffin Road Trip with Smarts scan for RDS + Power $ 99.95. All products are recommended by Apple, the producer and distributor of iPods and all are available through the online store Apple Auto Accessories.<br /> <p> <br /> <p>2. Attach confirmation that the iPod radio tuner device purchased at the door on your iPod and plug the other end of the device in device port Charger / charger in his 2002 Miata. Depending on the interior options that you selected for your Miata, and the automatic or manual transmission, the device port cigarette lighter / charger is located in the panel below the radio in the glove compartment or center console area between the two banks front. <br /> <p><br /> <p>3. Miata Turn on the radio and choose a radio station with little or no audible sound. Typical among the 90 FM stations are reserved for local stations with low transmission towers, so they are often your best option. <br /> <p><br /> <p>4. Connect your iPod and select the radio through stereo cables to your Miata on your device FM radio tuner. For example, if your radio is tuned to 88.1 Miata, you have radio receiver can be tuned to 88.1. <br />
on Aug 09, 2011 • Apple iPod touch
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
2helpful
I recently moved and no longer have a television. I would like to stream tv on my monitor for my apple desktop. What is the best way to go about doing this and the possibility of using a remote?
I would like to stream tv on my monitor Anon, Check the attached links,instruction and guides to see how to stream TV on monitor and have a remote, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Turn Computer Monitor Into TV
How Im using my iMac as my only TV
Use your mac as television
My yamaha rx-v473 wont turn on
disconnect all wires from behind unit, speakers, input, and then try to power it up ,
if problem persist then try to tighten screws on back panel of the unit,
may sound silly but if amp board does not have good ground connection it can do that , go in protect mode .
happened to me ...
Yamaha rx v473 cuts off
disconnect all speakers, turn it on. If it stays on, connect one pair of speakers at a time and when it shuts off, that speaker is the problem. There may be a short in the wire or the speaker may be bad. If you get that far, try connecting the bad speaker with another speakers wires.
1helpful
To use the fm radio do I need to have internet coverage
Hello there...
Well, it depends where you'd like to listen to. If you want to listen to foreign FM stations then you need to be connected to the internet to do so. But if you just wants to listen to your local FM stations then you just need your phone's headset.
4helpful
How can i have FM radio on my nokia e65?
If Menu -> Media does not shoe any Internet Radio (you have to have GPRS connection for it) then go to Nokia site and download the Internet Radio. The best Radio. All Fm radios, about 2000 of them All languages, all countries, all types. Otherwise, there is no way you can listen to local FM stations.
Wireless Modem don"t connect
well imac G4's don't  have built in airport (wireless internet) included as usual with apple its another item you must buy an airport extreme card  then hook it up to an airport base station another item to buy via wireless internet then hook you airport extreme base station up to your modem via ethernet. whew ok now sync the airport base station to your imac using airport set up application then select your network and type your WEP password and viol internet in about 1 hour if your lucky hope this helped my fingers hurt now LOL.
Top Yamaha Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
