Question about Brother MFC-7820N Laser Printer
Brother 2270 laser printer started jamming every time, after I installed a new toner. It was a Brother toner, at that. Anyone experience this?
Brother laser printer model 2270 ..... I replaced a toner in my printer, and ever since I did .... I've been experiencing "big time" paper jams! It makes no sense to me .... I've taken out ...put it back in...a dozen times ...and stillll can't figure it out.... Any ideas?
Posted by tc773 on
Andrew Henderson
    Sergeant:
  • Brother Expert
  • 394 Answers
Silly question first - is the drum unit DR2225 installed?
Check the toner cartridge sits firmly in the drum and that the drum is pushed all the way forward in the internal cavity. If the paper is jamming at the paper pick up roller ie in the paper tray, clean the paper pick up roller with a drop of meths and a drop of detergent on a damp cloth. If the paper jams in the drum unit, check the clear plastic guide flaps are straight and do not catch the paper. Also check that there is not a piece of paper caught in the drum unit. If the paper gets part way through the drum and then jams, check the fuser at the back for a piece of paper crumpled up inside the fuser. If the printer is trying to take ALL the paper at once, check and clean the paper separation shoe in the paper tray.
Posted on Jan 04, 2018
5 Related Answers
Anonymous
SOURCE: Paper Jam
it maybe the paper......make sure your paper is laser print paper and right thickness....
Posted on Apr 30, 2007
Anonymous
SOURCE: Paper JAm
There are three places to clear the jam: 1. Paper tray (remove it and feel inside, clear paper. 2.Open the front (above the manual feed slot) inside is the drum - remove that and the toner cartridge, if necessary. 3. On the back - open the rear chute. You should be able to remove the paper in one of those areas. See the Brother web site for complete pictures ans instructions. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_006.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=4
Posted on Aug 28, 2007
Anonymous
SOURCE: Badly jammed Brother HL 5040 B&W laser printer
If you remove the drum unit and cartridge it will all come out in one go.
Open the right hand end. The black T700 cartrige will be seen and it looks as if it is screwed in. However it is NOT just get a firm grip and pull the entire unit out (It snaps in and is quite tight... keep pulling it will come and there are no clips to break as you pull)
As it is removed, all the paper will come out in one go. A bit daunting if you have not done it before. Refit is the exact reverse, push it in quite firmly and it will latch back in place with a pleasing clunk! Hope that helps.
Posted on Jan 24, 2009
Anonymous
SOURCE: Paper Jam lite is on ( no paper jam )
did you try turning it off and then back on?
Posted on May 27, 2009
phillycopier
  • 13 Answers
SOURCE: Repeated paper jams from the brother hl2070n after remove toner
  1. Remove left cover (where the USB connection is located);
  2. Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore. http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Posted on Apr 15, 2010
I have a Brother HL-2142 Compact High quality mono laser printer and I am having trouble putting the new toner cartridge back in as it flashes error and the paper gets jammed. I dont know where the...
Open the front door and pull the whole toner and drum unit out of printer. The toner locking lever is usually on the left hand side as you see it and is usually blue in colour. It needs compressing and at the same time lift the front of the toner cartridge out of the drum unit. Your new cartridge will simply lock into place. When you install the complete unit and close the door, the new toner cartridge will reset your printers counter.
May 20, 2011 | Digital Products Brother HL-2040 Laser...
My printer displays Stack Copies constantly and will not print from my computer.
I have a brother hl-2280dw printer with same issue. Happened after I installed a new toner cartridge.
Brother advised re-installing driver. Did not fix problem.
Any ideas....anyone
Jan 19, 2011 | Brother DCP-7020 All-In-One Laser Printer
Paper jam in printer. Error light blinking.Can't get paper out
Turn the printer off, Open the front cover where the drum and toner are installed. Remove the drum and toner (cartridge). look inside the machine for a paper jam, also open the back cover and check there.
Apr 23, 2010 | Brother HL-2170W Laser Printer
Toner cartridge wiil not come out? paper is jammed brother 2030
You need to open the front door and grab the toner/drum unit and pull as hard as you need to. once the assy. comes out you press the blue button on the left side and the toner cartridge will separate from the drum unit. install the new toner or remove the paper jam as required. call if you need more info. 805-520-3003 steven
Feb 13, 2010 | Brother HL-2030 Laser Printer
Laser printer horizontal streaks go away after a few pages
The operating principles behind laser printers are fairly simple. In fact, Brother machines more closely resemble large copiers than conventional laser printers, this is why they are so reliable.
There are a couple of things to look at:
On the drum unit: is the imaging drum worn or scratched? When did you last clean the corona wire?
If the drum is scratched or otherwise with defect it should be replaced. If the corona wire is dirty it can fail to properly charge the drum and lead to print defects.
On the toner cartridge: Does the toner roller have any noticeable lines or banding in the toner?
Behind the toner roller is a "Doctor Blade" that ensures an even and consistent coating of toner. If there are lines in it they can produce print defects as well. Lines would be likely caused by toner accumulation on that blade. If there are lines, are you are careful, you may be able to clean the blade by gently and slowly scrubbing the non adhesive end of a post-it note between the toner roller and the doctor blade where the lines are.
Jan 15, 2010 | Brother HL-2070N Laser Printer
Brother MFC6800-says change drum soon - is that hard to do?
yes anyone can do this, the drum is the unit the toner fits into, remove as though you were removing the toner cartridge, that the toner all the way out of the drum unit and install the old toner in the new drum and slide back into printer, again the drum unit is just the casing that your toner cartridge slips in and out of
Apr 02, 2009 | Brother MFC-7220 All-In-One Laser Printer
How do I reset the drum life of a DCP7010
never ver use refil toner on brother products. to answere your first question 1 open the front cover 2 push menue button scroll down to machine info press set buton 3 scroll down to drun lif - push set
Jan 09, 2009 | Brother DCP 7010 Multifunction Laser...
New toner cartridge and paper jam
Does this happen when you install the old toner? Is the NEW toner an OEM or compatible? I have run into this problem before on some other Brother all in one models. There is a sensor flag located just below the toner and drum unit. Remove the toner/drum unit, check that the sensor flag will move to back and forth freely. My customer removed the toner and drum unit and threw the drum unit away, not realizing that the toner seats into the drum unit. When they placed just the toner into the printer, it read paper jam. Because the drum unit is part of the paper path, the sensor was not in the correct position.
Try re-seating the toner into the drum unit and then re-seat the entire unit into the printer. Let me know if this helps.
Oct 20, 2008 | Brother DCP-7020 All-In-One Laser Printer
NEW TONER INSTALATION
Non gen toner or fuser gear smashed, replace toner or fuser assy NO NEED TO YELL
Dec 26, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-7820N Laser Printer Logo
80 people viewed this question
Norman  J Weimar Jr
Norman J Weimar Jr
k24674
