We had a power outage last night and now my HCI tv won't come on how do I get it to turn on
Hi Michelle, if your TV does not turn on anything, not even the stanby light, it means that presumably, the input fuse has been burned and / or in the worst case the power source
If you have technical knowledge, disarm the TV, locate the fuse, (replace it with one of equal value, if you put one of higher value you have the risk that you can cause more damage) and reconnects, if it burns again, consult a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Michelle, si tu televisor, no enciende nada, ni siquiera la luz de stanby, quiere decir que presumible-mente, se ha quemado el fusible de entrada y/o en el peor de los casos la fuente de alimentaci?n
Si tienes conocimientos t?cnicos, desarma el televisor, ubica el fusible, (reemplazalo por uno di igual valor, si le pones uno de mayor valor tienes el riesgo de que puedas producir un da?o mayor) y vuelve a conectar, si se vuelve a quemar, consulta a un servicio t?cnico especializado
Espero Puedas resolver el problema
Saludos Franco Dosil
