Question about Toshiba Satellite L300D-ST3501 Notebook
Installed bios update for the wrong operating system. I think it was Windows 7 and I have Win Vista. I downloaded, opened and then installed. The screen turned black and I haven't been able to do anthing since. I have tried to take the battery out and unplug power cord to see if I can boot into safe mode. It does nothing. I'm not computer savvy but I can get along with good directions. Can I revert back to original bios? I have even tried it on another display. This was the original problem, I believe when I hooked it up to display on my plazma screen. It started to have blue screens and the errors indicated display drivers. I went to Microsoft solutions and it prompted me to install a bios update and to update my nvidia drivers.
You may have killed your laptop. BIOS have little to do with an OS like Windows, Linux, etc. The display issue is the culprit. Using another computer go to Toshiba website a get the current BIOS for your laptop. Are you able to access the BIOS at all? (press Del during bootup? to enter the Config screen (looks like DOS)
Posted on Mar 25, 2013
SOURCE: toshiba satellite a215s7422 screen blackout problem
As you can see an image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 06, 2009
SOURCE: i have a toshiba satellite
http://www.4shared.com/file/oE15gXll/killdisk_and_boot-cd-iso.html
get this from my shared drive(read instructions in there)
and wipe your disk clean (Warning...this process will make you lose all data on disk so be careful, if posible backup all critical data that you need)
once done install WinXP SP3(get a Windows XP cd from a friend or download a pirated copy from net) look for "WinXP SP3 piratebay" in google
when installing WinXP make more than 2 partitions (C, D, E)
Install WinXP in C
once done, let Windows boot and show Desktop
install WinVista or Win7 in D
use E for saving your critical data
Posted on Nov 29, 2010
Feb 19, 2014 | Computers & Internet
Feb 12, 2012 | Toshiba Satellite A25-S2792 P4 3.06GHz...
Jul 17, 2011 | Computers & Internet
Feb 06, 2018 | Computers & Internet
Apr 01, 2011 | Toshiba Satellite L305D-S5881 Notebook
Aug 08, 2010 | Toshiba Satellite A135-S4527 Notebook
Feb 19, 2010 | Toshiba Satellite L300D-ST3501 Notebook
Jan 08, 2010 | Toshiba (P000257700) Microphone
Mar 22, 2009 | Toshiba Satellite Pro L300D-EZ1006V...
Feb 05, 2009 | Toshiba Satellite A100-S8111TD Notebook
Feb 16, 2014 | Toshiba Satellite L300D-ST3501 Notebook
155 people viewed this question
Oh Gawd! Pls don't say that. Lets try other solutions. I'd even go as far as losing all data and installing a new version of Windows. Is there a startup disk that can be created? I did get the correct download for it. Pls lets try more things before we say it died...pls..:-(
No, I cannot access the bios at all.
