i too have a Toshiba 42wlt66 that wont switch on a keeps clicking but not turning oni too have a Toshiba 42wlt66 that wont switch on a keeps clicking but not turning on
You can't post conmments that contain an email address.
Fault with main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
The clicking/ticking sound could be from the power supply board - being cheap designs nowadays those tend to fail rapidly. Tiny surface mount components on these boards can short or go open circuit, making visual inspection next to impossible and you wouldn't be able to tell if any of them were bad or not, just by looking. Power supplies are usually the primary source of most click/ticking sounds in TVs and are a good place to start investigating. Usually the only way to repair modern TVs is by ordering an exchange board (from the manufacturer or their agents) to replace the original suspect faulty one (the parts are just too small and expensive to replace individually) - you aren't meant to repair a factory board.
that relay is supposed to engage power to the tv boards that control the screen.
you will have to take it to a oualified service center , because they have access to parts that are needed for repair
This is a typical condition if the power supply has failed or a power-consuming circuit the supply services has exceeded a predetermined current draw. The relay you hear is preventing further damage or even fire. You will need local tech help with this.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
