I have two questions. The tray under the coffee doesn't collect water like my old $700 Krups. Just the large pan, which doesn't seem to hold much water. Second there is an extra piece that came with the machine, does that go someplace?
SOURCE: A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at [email protected].
SOURCE: KRUPS XP7240 leaking water
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver.
Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072.
Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
Good luck.
SOURCE: Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
SOURCE: krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter: http://www.microcenter.com/single_product_results.phtml?product_id=0332974
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
SOURCE: My Krups XN2005 coffee machine switches itself off
My Krups Nespresso XN2005 machine turns itself off when I try press the start button- any solutions ?
