Question about ASUS P4SGX-MX Motherboard
Click here for your wiring diagram Hope this helps.
Click here for live tech support
Posted on Mar 24, 2013
SOURCE: asus p4s800-mx
The problem is most likely bad capacitors. The may have used a bad batch, with many people having such issues. I understand it is difficult to get several of the caps out without ruining the board completely, so it may not be worth the time and effort it would take to replace them.
Posted on Jan 27, 2008
SOURCE: upgade motherboard
What problem is it that you are having?
If you want to upgrade you're CPU here is the Asus link for supported CPU's P4S800-MX motherboard.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P4S800-MX
To the right of the list is the bios file that must be used to support the CPU.
If you need instruction on how to replace a CPU just let me know.
Mike
Posted on Jul 21, 2008
SOURCE: i need to know which wires is put where...i need a diagram
http://joule.bu.edu/~hazen/LinuxCluster/e1447_p4s800-mx.pdf
Posted on May 29, 2009
SOURCE: Asus motherboard
You'll just need to troubleshoot a little. 1: Try the monitor itself on a second PC. 2:If it doesn't work you've found your failing component. 3: If it does work try the PC<-->monitor cable on another PC. 4: See step 2. 5: If that also works, your graphics card is the only thing left. Take it out and put it in another PC. 6: Repeat step 2. 7: One of the components I listed should be the broken one. Of it isn't please post back here. I hope this helps, Yannick.
Posted on Jun 08, 2009
SOURCE: What isthe maximum size hard
I think that it would support IDE HDD atleat up to 320GB. As i have used 320GB HDD with similar Asus board
Download the motherboard manual for information and guidance on the subject.
Posted on Nov 03, 2010
