Question about Whirlpool LSR9434PT Top Load Washer
Whirlpool washer la5800xm wont stop pumping water
Water pump is constantly pumping water accept when filling
Posted by chris on
  • chris Mar 24, 2013
    to clarify, it is the drain pump that is not stopping during any cycle accept for when the machine is filling
5 Related Answers
Anonymous
  • 72 Answers
SOURCE: Washer Will Not Fill
Could you retype this to better describe?
Posted on Feb 25, 2007
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Whirlpool duet Model ghw9200lw
The errrors are generally related to one another. The "F02" error is a slow drain problem. The "SUD" gets generated because it senses air in your drain pump (due to a possible blockage). More than likely you have an obstruction in your drain pump and you will need to clean it out. This is probably the reason for the pump sounding strange too. The following link explains how:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Follow the link provided and this should be a an easy process for you. Keep in mind, however, that if there has been something obstructing your drain pump for any significant length of time, you may have damaged to pump. It doesn't take much to cause irrrepairable damage (I know, its a crappy design). If you clean out the drain pump reservoir, and the error(s) reappear, you will have to replace the drain pump.
If you require a replacment pump, you can purchase a new one on line at searspartsdirect.com. Just type in your model number and the pump can be located under the "Pump and Motor Parts" heading as item number 10 (part #8181684). For instructions on how to replace the pump, follow this link:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Hopefully, it won't come to the point of replacing the pump, but you have the information if you need to. I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 30, 2008
honeymokey
honeymokey
  • 3113 Answers
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Posted on Jun 18, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: How do I access the pump on a whirlpool Ultimate Care II
A bad pump would not affect a washer's ability to spin. It would only affect the drain function. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have questions, please let me know. I hope this helps you.
Posted on Aug 04, 2009
Anonymous
  • 125 Answers
SOURCE: Whirlpool Thin Twin Washer - does not drain water.
MAKE SURE THE CONNECTION ON THE TOP PANEL FOR THE LID SWITCH IS GOOD. ON OCCASION WHEN THE TOP PANEL IS SLID BACK IT CAN BEND THE BRACKET THAT HOLDS THE FEMALE END ON THE CONNECTION. HOPE THIS HELPS
Posted on Feb 11, 2010
My Calypso washer at the start I hear water filling tub. Then it stops filling and hear a moderate humming noise. I replaced water pump but still doing the same. Please help. Thanks
The problem is not the pump. IT appears that the water control valve is bad or the voltage that controls it is changing and then the valve stops working.
Dec 24, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Constant filling and siphoning of water sans cycle.
Remove the front panel and open the control panel. Check all wires for loose or broken connections.
Dec 06, 2011 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool washer LA5800XM has water leak, how can I fix this
The water pump is often what leaks. You will have to remvoe the case of the washer to see if that is the problem. This page will help http://www.appliance-repair-it.com/Whirlpool-washer-leaking.html
Aug 24, 2010 | Whirlpool LSR9434PT Top Load Washer
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water won't dump
When you replace the pump, always to remember to makes sure the pump is pushed all the way in so that the shaft has a good grip. Try taking it out and pushing it all the way in. The 4 legs should touch the motor, as you put the 2 little clamps on the top and bottom.
Good luck, I'm pretty sure it's something really basic with the pump :)
Jul 19, 2009 | Whirlpool LTE6234D Top Load Stacked...
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer machine Whirlpool Ultimate Care II LSQ9549L is leaking water when I fill the tub with water. I opened cabinet and there is a small white box below the tub that is dripping water. My questions are...
is it filling filling filling and not stopping. or will it fill and stop when it is supposed to. if it's fill fill filling could be a hole in the pressure hose or a faulty pressure switch. but if itt does all the cycles and is leaking you probably have a bad pump tip the unit back a little so you can see under but do not tip all the way you will see the pump. see if it leaking if so replace tha pump.
Jan 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer LSQ9264HQ
Either you have a faulty water valve, which would either need to be fixed or cleaned, or you have constant power to the valve caused by a problem in the controller which does not allow the cycle to advance. If, as you say, it does not overfill, then apparently your water level control pressure switch is operating and causing the pump to turn on and drain as fast as it fills.
Feb 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Need help
pump got nothing to do with water level only pressure sw vary it
May 10, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool LSR9434PT Top Load Washer Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
