Question about Leapfrog Enterprises Leapfrog Leappad Explorer Green - LFC32200
Leappad 2 was washed in water, everything works except the power button will not turn it off and there is moisture behind the screen..how do I fix it?
LeapPad 2...washed in water. Moisture inside the machine. Power button will not turn it off.
Posted by cassandra miller on
How do I Reset leappad 3
It’s simple, when prompted for the 4 digit parental code, enter 1 9 6 backspace 8 7. This will bypass the parental code for you,
Apr 17, 2016 | LeapFrog Leappad Explorer Learning Tablet,...
Cold water valve not working. have checked that water is at outlet of cold water tap. Can you help? thank you
Water Valve Test
When in Diagnostic Mode, the WASH TEMP UP button turns the hot water valve on. The Hot LED is on when the hot valve is on. The WASH TEMP DOWN button turns the cold water valve on. The Cold LED is on when the cold valve is on.
DIAGNOSTIC MODE
Turn the power on at the power point but off at the machine. Press and hold the WASH TEMP DOWN button and then the POWER button until the machine gives 2 short beeps and lights up. Release buttons when the beeps indicate diagnostic mode has been entered.
There maybe up to 3 filters cold water line. There is sometimes 1 at each end of the water hose itself and also in the valve which can be removed with pliers. (see picture)
Undo the 2 screws at the back of the buttons panel
Undo the connection of the valve
If you are good with a multimeter check that there is about 65 ohms resistance across the terminals of the valve. If not, then replace the valve.
Also sometimes the workings inside the valve can jam shut so replace the valve.
Dec 27, 2014 | Fisher and Paykel GWL11 Top Load Washer
Leappad 2 ultra would not come on after my daughter poured water on it
Try sitting the leap pad in a bowl of uncooked rice (the rice will absorb moisture) leave it in there for a day or 2, then try again, with new batteries.
Good luck.
Jun 24, 2014 | Computers & Internet
My leappad 2 wont turn on
My new leap pad 2 wont turn on?
Dec 16, 2012 | LeapFrog Leappad Tablet Bundle
Leappad game was dropped in water, How long does it need to dry out or is it ruined
place it in a small container of rice for about 3 weeks,to absorb moisture.then try it out.
Apr 25, 2012 | Leapfrog Enterprises Leapfrog Leappad...
LeapPad stuck on Leap Frog screen.
I have the same problem. did you ever find an answer???
Feb 17, 2012 | LeapFrog Leappad Plus Writing
Mold growing
If you mean on the outside of the machine, there is probably a slow water leak, and it is soaking the floor which is making to much moisture.
If your talking inside the machine.
Try and wash by hand the machine with a 50/50 bleach/water/ and a 1/4
cup dish detergent.
Run the machine through a full wash cycle, with a 1/2 gallon bleach
in a small load setting,
Then run the machine with full load setting and nothing for detergent, just the water, say three times. To flush all the cleaning you did away.
From now on leave the door open when done so if there is any water or moisture inside it does not stagnate.
Feb 08, 2010 | Frigidaire GLTF2940ES Front Load Washer
Machine has got wet inside casing in bad weather -
this machine would need to be tested there are many things it could be unless you are compedent have it checked by an engineer
Jan 16, 2010 | Washing Machines
How do you restart washing machine?
plug in power and turn program button at off(0),then open water and choose a program
Feb 17, 2009 | Kenmore Elite 45986 Front Load Washer
Leappad won't turn on
If you press the power button and the home button at the same time, count to ten while holding them down together, then let the buttons go after a count of ten, then press the power button, it should turn on. this is a reset for the leappad. most times works in most cases.
Jul 25, 2008 | Toys
Leapfrog Enterprises Leapfrog Leappad Explorer Green - LFC32200 Logo
80 people viewed this question
Top Leapfrog Enterprises Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Leapfrog Enterprises Toy Expert? Answer questions, earn points and help others
