Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Watched our wd52531 yesterday, turned on today and no sound... Hooked up external system and no sound either. Does the lamp have anything to do with the sound?
This tv is not our main system, so it doesn't get used as much. It also has been a couple of years since we replaced the bulb, and it has kicked off a couple of times within the last month showing the lamp needs replaced. Figured when it went out I would replace then. Wondered if that had anything to do with the sound.
Posted by Norman Bragg on
Robert Smith
    Champion:
  • 213 Answers
NO THE LAMP DO NOT HAVE ENY THING TO DO WITH THE SOUND IF THE LAMP WAS BAD IT WILL NOT RUN AT ALL
Posted on Nov 25, 2013
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Posted on Mar 21, 2007
Anonymous
  • 146 Answers
SOURCE: wd-52531 has sound, then clicks off after few seconds
It can be the lamp. But the color wheel and ballast can cause the same thing. Put your ear to the back of the set when you push the power button and you should can here the color wheel start up. If not, that is your problem.
Now if the lamp is not lighting up. you should here a ticking sound from the back of the set, if not the ballast is bad. If the lamp is coming on and then going out after only about 5 seconds AND you do not here the start up of the color wheel, the color wheel is confeirmed bad.
Posted on Nov 20, 2008
lauracalla
  • 3 Answers
SOURCE: Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Posted on May 07, 2009
ladywinn
ladywinn
  • 5138 Answers
SOURCE: Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Posted on Sep 27, 2009
Guest
  • 3 Answers
SOURCE: My tv mitsubishi wd-60735 turns
Don't know if this applys to you but if you have purchased anything but Osram or Philips replacement lamp for your DLP tv then this is probably your problem.. The generic is VERY tempting in this recession but in this case generic is poison to your dlp tv... i have a Mitsubishi 60735 and went thru 2 generic bulbs when my tv kept shutting down on it's own and the lights on front would flash, i could cut it back on for 10 minutes then flicker and shut down again ..well since the bulb was new i thought it may be defective so i got is exchanged for another one ... after all of the post i have seen how much repairs were going to cost on dlp sets no matter what the problem was ..i was ready to chunk the tv out the door when the second lamp was doing the same thing.....!! well a last ditch effort to save my tv before i trashed it or taking it apart to dissect it.. was to buy a brandname lamp ... in my case i purchased a Philips ..it cost twice as much =/ ..i could just return it if it didn't work.. well it was the generic lamps that was causing trouble.. the brandname worked perfectly .. i am just glad the generic lamp didn't do any damage to my TV!!! I have done further research on the generic lamps and realized that the damage it could have done was not worth the money i saved when i purchesed it... Generic is a great deal In some cases (household cleaners, etc..) but in this case GET THE NAME BRAND!!!! the only name brands i know of for these lamps are Philips or Osram/Sylvania.. hope this helps others from this headache. Do your research don't by generic lamp replacements, your DLP set cost to much to risk it.
Posted on Feb 16, 2012
Troubleshoot sound bar
replace optical cable or re install toslink cable
Sep 02, 2014 | Audio Players & Recorders
I just purchased the RCA RT2910 Theater System yesterday. When I hooked everything up, it was all working great. However, tonight when I was turned it on, all of the speakers were acting weird. They would...
What source(s)? Verify the speaker setup with the test tones to prove the hardware is all okay. Then go back and evaluate the conditions that create the problem. It could be an external cause.
Jun 01, 2011 | RCA RT2910 Theater System
Blinking red light
I am in the same boat as you are. My wife and I had watched the Steeler MNF game yesterday evening and today when I went to turn on the Pens game, all I got was a blinking red light and a "power on" sound...wtf...Can anyone help? I'm definitely not a techie nor have I ever soldered anything...
Sep 29, 2009 | Toshiba 53H71 53 in. Rear Projection...
Green light at start up but green light goes off
sounds like your lamp may have gone out. check your manual as to changing lamp.
Sep 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
87 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
