My netbook Samsung np305 keeps freezing. I tried the auto repair and that stayed on an endless loop and didn't resolve anything. I tried samsung recovery and did a basic restore but that didn't help. And it won't let me run in safe mode, it starts to run but freezes whilst loading up.
Posted by Emma on
bob bobert
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
Probably the hard drive
Posted on Mar 24, 2013
2 Related Answers
Anonymous
  • 137 Answers
SOURCE: My VAIO Laptop screen keeps freezing when i run windows normally
Restoring the computer back to factory settings would be the smartest thing to do. but its not a solution. i would recommend that try to reinstall the os and create a parition and save all your information on the other partition. Not on C but anywhere on D, E etc. or you can use an external hdd for this purpose which will back up your information automatically. so you wont think twice restoring it back to factory settings. if you are using windows vista. i suggest turn off automatic updates. because updates causes lot of issues than they resolve.
so as of now you may restore it back to factory settings and turn off the updates. this will certainely work out. SONY's laptop si a good laptop and it hardly cause any hardware problem. so its just vista.
The fool proof option is
Install XP and say good bye to all crashes. ;)
All the best.
Please rate this information a HIGH RAnk if this was a helpful information.
Posted on Sep 23, 2009
Anonymous
  • 18 Answers
SOURCE: My Toshiba A200 laptop keeps freezing up about 1-5
I think you antiwirus has damaged the system files and you should just re instal the opperating system
Posted on Nov 18, 2009
My tablet will not turn off. It keeps restarting but will not get past the iRola screen.
About 15,600,000 results (0.52 seconds) Search Results
    The tab is in an endless reboot loop. - Samsung Galaxy Tab ...
    https://www.ifixit.com/.../The+tab+is+in+an+endless+reboot+loop.
    iFixitMy samsung galaxy tab 2 7.0 is turning on and off continuously. ... The second iteration of Samsung Galaxy Tab tablet computers with a 7.0 inch screen. .... to lose all the data, but still it does not lose and keep restarting over and over again.
    it keeps switching itself off - Samsung Galaxy Tab 3 10.1 - iFixit
    https://www.ifixit.com/Answers/View/.../it+keeps+switching+itself+o...
    iFixitMy Samsung galaxy tab 3 charges badly and keeps turning off and not coming ....What you will need to do is take the tablet apart, (carefully) and secure the battery to..... It shuts itself off and I have noticed that upon restart the Wifi is turned off.
    How to fix any Samsung Phone/Tablet that keeps rebooting ...
    ? 3:03
    https://www.youtube.com/watch?v=A-0LgvM-WNs
    May 30, 2014 - Uploaded by lennonSystems
    How to fix any Samsung Phone/Tablet that keeps rebooting(Boot Loop). lennonSystems ... with the s3 it does not work. trow it in the trash can ... When my phone does this I just let it do its thing, after a while it would stop.
Feb 09, 2016 | Tablets & eReaders
Boot loop
try pressing the power button and holding it for 10 seconds. Then wait a while. Turn it back on, you may press F12 or other key when the Samsung Logo appears (before Windows Logo) to see the boot options. Choose the one to check for any errors or anything else - Run diagnostics. Then also you may scan your hard drive for any failures.
Jun 04, 2013 | Samsung NF210-A02 Netbook
Samsung NP305 laptop freezes
Bottom line here you have a warranty use it.
Feb 17, 2012 | Samsung Cell Phones
Hello, I've forgotten the bios password on my samsung N130. Is there anything you can do to help please. Thank you
http://unlockbiosrecovery.com/Unlock_Samsung_Bios.php can supply you with the master bios password for you Samsung Netbook for just $20 plus they guarantee it to work. I use them in my work as a laptop repair tech and they always work.
Aug 18, 2011 | Samsung N310-13GB Netbook
Hi my samsung netbook just hang, the mouse is moving but I can't click anything, when I try to click an icon,it's in waiting mode so i can't click it. I tried to turn off the switch but it...
Pull the plug and shut down. Naturally your computer will turn off and it should try to redstart when turned back on.
Hopefully, your startup (Boot) will function and take you to the normal window. If not, the hard drive may have become defective and stopped working.
Feb 17, 2018 | Samsung N150 (36725723009) Netbook
Hi! Last night, my Samsung N150 was still working properly. But when I connect a music player, it stopped working. When I restarted it, the taskbar was already stretched upward and the start button failed...
Try running you're antivirus. Scan you're drive and you're music player because i'm assuming that you're music had a virus that attached itself to you're netbook. If that didn't worked or you're antivirus didn't run at all ( because some viruses and specially malwares can actually do that ) try running it in safe mode (pressing f8 during initial boot) or run you're system recovery in safe mode (this will revert you're system to the date you're netbook didn't have any problems).
To prevent this kind of problem in the future i would suggest turning off you're autorun. Try running this procedure http://antivirus.about.com/od/securitytips/ht/autorun.htm
If you're having a hard time understanding it the easiest way to do it closing the autorun pop out once you insert you're music player. Then just double click you're computer then right click on the drive then select explore. And make sure that anything you insert in you're netbook in the future to scan it first with you're antivirus before doing anything.
Hope this helps. Good Day. ( :
Jul 15, 2011 | Samsung N150 (36725723009) Netbook
Samsung n148 loaded with Win XP pro has gone into a loop. It starts to boot says windows is starting then I get a blue screen and the system shuts and this loop carries on. Pressing F4 which is the...
mscam ... Microsoft Camera... Hmm make sure you have disconnected all items from your system... try to boot up in safe mode... if that doesn't work you will have to do a repair with a Windows cd... do not do a repair with the internet software... last resort reinstall windows
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Jun 29, 2011 | Samsung N150 (36725723009) Netbook
Computers & Internet Logo
159 people viewed this question
Ekse
Marvin
Marvin
