SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
SOURCE: LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
SOURCE: My Dometic rv Refrigerator does not cool the lower
If the freezers ok, then airflow is the issue, as the reefer gets its air from the freezer, set the dial that does not operate the compressor to the middle setting, pegging it to cold, makes the freezer colder by starving the reefer!, very common call requiring no repair , just a setting change!! never peg it!!
SOURCE: i have electrocool LG MOdel# GR-382R ser#
I have the same problem.It seems that the gasket around the freezer door and fridge door are no longer tightly adhering to the fridge therefore allowing the cool air from the freezer to continiuously entering the fridge storage and making evreything freeze up. I am trying to find out if I can purchase new gaskets and install them myself.
Any recommendation on where to find these and how to install them?
Thanks.
