SOURCE: I have 1992 Dodge D150 with 318 magnum. It won't
is this vehicle fitted with a chipped key ?? iam thinking factory immobilisor here?? but not sure what year it was introduced in america
SOURCE: How do you replace the water pump on a 1996 dodge
remove then neg battery terminal. remove the serpitine belt. remove the fan clutch assembly. remove the fan shroud. remove the altinater and a.c pump. remove the alt and a/c pump bracket. remove the heater hose and inlet pipe. remove the intake manifold cooling hose. remove the lower radiator hose from the pump. finally unbolt the pump and remove. be sure and drain the coolant first. hope this helps
