Samsung SyncMaster 931B 19" LCD Monitor Logo
A
Anonymous Posted on Mar 24, 2013
How do I reset a syncmasster 931b monitor to factory defaults
How can I set my DELL E2210Hc monitor to reset to factory default
To help you reset default settings of Dell monitor, please find the instructions step-by-step given below:
- Press the 'Menu' button on the monitor panel.
- Press 'Plus(+) or Minus(-)' button to move to 'Menu Settings'.
- Again press the 'Menu' button.
- Press 'Plus(+) or Minus(-)' button to move to 'Factory Reset'.
- Again press the 'Menu' button 'Twice to Reset'.
- Press 'Plus(+) or Minus(-)' button to move to 'Exit Menu'.
GuruAid.com
How to reset eizo monitor
resetting Eizo monitors - RetouchPRO
www.retouchpro.com > RetouchPRO > Tools > Hardware
Apr 10, 2008 - 6 posts - ‎4 authors
is it possible to rest a CG241W to the default factory settings?..the consultant that is working with us is having trouble getting a decent ...
Eizo
www.eizo.se/default.aspx?page=21
EizoOften there are no faulty sub-pixel on a EIZO LCD monitor, but according to the EIZO... Reset the monitor to the factory default settings by choosing 'Reset* in the ...
Setting Eizo Logo Display On/off; Resuming The Default ...
www.manualslib.com > ... > Monitor > FlexScan S2202W > User manual
The EIZO logo appears on the display when turning on the monitor. This ... default settings, and the other is to reset all the settings to the default settings. ?.
Monitor screen has shrunk down from top and up from bottom
There has to be a setting in the menu for the monitor...I would look in the menu in the monitor settings on the monitor itself, and find a reset selection, to set it back..
Reset defaults on monitor
When you are on on screen menu setup, there should be 'reset to factory setting' to put it back to factory default setting. I am not sure which exact model you have, but you cann download user manuals here:
http://www.retrevo.com/search?q=LG+Flatron+L1718S+
5helpful
How to master reset
Master Reset or Factory Reset
When Factory Reset is performed, the setup value will factory default setting
When initialization starts.
1.Select System Setup from Menu Screen.
2.From the System setup submenu, Set Factory Reset to ON
3.When you exit Menu, The phrase FACTORY RESET Appears on the monitor and
The Initialization starts.{ON/OFF} Use arrows UP-- DOWN & , kEY TO MAKE CHANGES
HOPE THIS HELPS
2helpful
931b flashes on &off
You need to open it up and look for caps with bulging tops. Common problem with ALL brand of monitors.
http://s807.photobucket.com/home/budm/allalbums
http://www.axtsystems.com/index.php?option=com_content&view=article&id=83:samsung931bfix&catid=48:fixingstuff&Itemid=81
Please post back what you find so it will help other people also. Use good caps, PANASONIC FM or FC series from DIGIKEY.
Cant get size from display settings for external 19" Samsung Sync Master 931B cant see start button everything to large
See if you can pull up the menu on your monitor. If you can reset it to factory defaults.
If you still can't see the screen properly then you need to on your computer. Go into the device manager and make sure its seeing your video card properly. Look underneath display adapters and be sure its seeing something other then standard display vga.
If not then your display adapters are missing so once you install those, the computer will recognize your monitor.
4helpful
I need to know how to reset my monitor to factory defaults
Factory Setting & EEPROM Initialization Method
Factory Setting Method
- Connect the signal cable and power cable to the LCD monitor.
- Press Power switch with pressed MENU key.(Menu key + Power key).
- Then, a User can change the factory setting value in OSD menu.
- Save changed value and Turn off the power s/w.
- Turn on the power, adjust the screen.
SyncNaster 931B
take a soft cloth (type used for cleaning glasses) and moisten it with a small amount of water on one corner.
gently wipe the wet portion of the cloth across the screen (if you have any weak alcohol based cleaners you can try it. I have used hand sanitizer before on my 931b w/out problems, I wouldn't use any extremely strong liquid cleaners though).
Use the dry part of the cloth to wipe the area dry, then move to another part of the monitor once you are satisfied.
931b monitor does not power up
Open the case, remove the power board and visually look for bulging caps. I replaced 3 on mine and now its prefect.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
