Samsung LE37R72B 37 in. HD-Ready LCD Television Logo
A
Anonymous Posted on Mar 23, 2013
I have a samsund LCD LE37S81B and when i turn the tv the contrast ist alwais on max
1 Related Answer
Anonymous
  • 456 Answers
  • Posted on Aug 27, 2009
SOURCE: i have a samsund LCD LE37S81B and when i turn the
If it happens when you only turn on the tv, it could be a factory setting, i suggest turning volume all the way down before shuting off unit and turning it back on. if it happens whislt watching tv, or at random, i feel you may have a problem with your audio output circuitry, Good luck.
2answers
Monitor colors lack contrast
Try using a preset picture setting & then compare that to your manual setting seems like you have gone out of sync.
I in mi aoc tv lcd l22w89 the option picture blocking, contrast and brightness to 100% and I can not change
In the menu system there is a reset (I believe it's all reset, or reset all...something like that) which should fix the issue.If not, leave the TV unplugged for 4 hours and plug it back in then turn it on.
I have a samsund LCD LE37S81B and when i turn the tv on the volume is always on max!what can i do??
Combo panasonic es40v cooling fan alwais on ?
Most of these units are a always on sitaution. Accept for TV's witch are temp controlled.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
13helpful
3answers
Samsung LCD tv wont turn on
what the full model number of your tv?
the clicking sound is the result of a faulty power supply, some capacitors(blown heads) on the power supply for the output voltage rail of the mains board need to be replaced.
pls rate me!
Samsung remote volume control returns to max sound on its own
dear, you have to check your +button whether it is holp the egde of your remote, open your remote and clean, and also check a button on tv for +volume button. there is a pulse condition sensed by the volume control stage. if you can manage do it, or take it to a technician.
Grainy Picture Denon 1740 DVD and Samsung 1080P LA40M81BD
Firstly, you should alter the picture settings on the TV. Most TVs have independant settings for tuner, scart and HDMI, so you may need to do this several times. Once for each.
Excessive contrast and/or sharpness on an LCD causes graininess, particularly around the edges of moving objects.
Check and adjust the following on the TV:
  • Contrast - about 65% max
  • Sharpness - 20%
These settings are a % of maximum, so you may need to work out a value if max is not 100.
Also turn off any contrast enhancements - (Contrast + / Digital
Contrast etc.) dependant on make.
I assume that you are using the upscaling facility of the Denon 1740 via an HDMI lead. If so, disconnect any other connections between the DVD and TV, particularly scart. If the scart is connected the TV will auto-switch to the scart input when you use the DVD, and you will not get the benefit of the high def connection.
This is probably obvious, but make sure the DVD is set to 1080p scaling, and you will need to manually select the HDMI input on the TV.
Blury pictures
change the resolution setting in setting. and also you can adjust diplay bright ness and contrast for bets view & pics .thsi will solve the problem. Thanks Sangita
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
