Question about Tappan 30IN ELEC IGNa Oven
Remove gas oven door tappan 12-3699 10/01 - Tappan 30IN ELEC IGNa Oven
2 Related Answers
Anonymous
SOURCE: Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
Posted on Oct 30, 2008
Anonymous
SOURCE: Tappan gas oven won't turn on
I cannot assist you with your problem, but I do have the same oven and it seems the control panel doesn't work either. However, I am looking for the manual. Would you perhaps be able to help me with that? Sincerely, S. Rozier
Posted on Apr 07, 2010
Yesterday my oven door wouldnt close all the way. I have a gas Tappan. There is a latch that is stopping it from closing
That's your door lock latch. its prob faulty. you can remove it by going through the top or just order the mechanism and replace. if you use the self clean feature, this happens quite a bit...
Sep 03, 2012 | AEG Ovens
My tappan gas oven (Model # 30-4942-0005) doesn't light
yes the igniter is not calling for enough amps to open the control valve, the igniter needs to be repalced.
Feb 01, 2010 | Tappan Ovens
Tappan gas range model 72-3981-00/07. Upper oven does not ignite even though the igniter comes on and glows yellow.
The ignitor is weak and must be replaced. When you get the new ignitor turn off the gas supply and the power to replace the ignitor.
Remove the oven racks,remove the oven base pan,remove the flame spreader to access the ignitor.
Jan 10, 2010 | Tappan Ovens
What does an F3 code mean on a Tappan oven/electric range? The lock on the oven door is sticking out not allowing me to shut the oven door all the way.
This is your oven temperature sensor on your Tappan Oven.
T
hese codes are designed to troubleshoot your appliances and prevent further electronic issues from happening to your unit.
It is a simple repair that you can repair yourself and you can save a ton of money, also!
Once this part has been replaced, you oven should close properly and work just fine.
Oct 19, 2009 | Tappan 30IN ELEC IGNa Oven
Wall oven removal and installation
Turn off the gas. Look in the front of the oven for mounting screws. Open the door and look inside the frame for mounting screws. Remove the mounting screws,slide the oven out carefully,it will be heavy. Unplug the cord.Disconnect the gas line. Set the oven aside in one piece.
Sep 25, 2009 | Ovens
Sep 08, 2009 | Tappan Ovens
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Tappan 30IN ELEC IGNa Oven Logo
64 people viewed this question
Top Tappan Ovens Experts
Marvin
Marvin
john h
Andrew Taylor
Andrew Taylor
Are you a Tappan Oven Expert? Answer questions, earn points and help others
