SOURCE: Can't power up
The buzzing noise you are hearing is most likely the ballast fire, this is good. You most likely have a bad lamp which is the best case for you. I would recommend pulling the lamp out and looking at it to see if its physically shattered or not.
The instructions for pulling the lamp can be found in your owners manual. If you do not have this anymore just look on the sides or the back of the tv for a small door with a screw or 2 in it. take those screws out and the door should come off, then take the screw(s) out of the lamp and pull it out. if you see glass rolling around inside you will need a new lamp. Let me know and I will help you find a good one at a good price.
Tim Nolan
SOURCE: My Panasonic tv pt53wx53g wont turn on it blinks 3 red lights
The 3 blinks is a error code for the convergence circuit. You can get the convergence repair kit for your model at the following link which contains both Convergence ICs and all six feed resistors and they include step by step instructions with pictures that show how to do the repair yourself. Heres a link to the proper kit for your model Panasonic.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @ [email protected]
hope this helps.
SOURCE: panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
SOURCE: MY PANASONIC PT-50DL54J DLP will just turn off. I
I have posted solutions for similar problems.
There may be a heat issue with the power supply components.
Remove the back panel and blow compressed air into all the component area, (except the fan on the right). The power supply is on the left.
Then vacuum all the dust out.
There may be a problem with the battery in the remote. Weaken batteries can cause the remote to send random signals (including turning off the set).
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
