SOURCE: MY sansa e260 MP3 player
Try to add the device manually.
Plug the player in while it’s set to "MTP" mode. (This selection is in the Settings area)
On your computer, open Device Manager, and select: Add Hardware.
Choose the "already connected the hardware" option.
From list, choose "Add a new hardware device".
Select: "Install the hardware that I manually select from a list."
Select: Portable Devices, then MTP device.
Hope it works for you.
SOURCE: Sansa® e250 MP3 Player 2GB
Mikey25
Once you connect your Sansa® e250, a pop-up should appear on your computer that asks what you want to do with the device. Choose View with Microsoft explorer, it should be the second to last option. From there you should see some folders and some other stuff. choose the PHOTO folder and delete the pictures inside. You should be able to do the opposite to add them. You can simply drag-and-drop the photos into this folder from another as long as they are the same format.
SOURCE: SANSA
Download the firmware updater for the sansa:
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
4. Follow the instructions to update your firmware.
5. If you need additional assistance try calling Sandisk's tech support:
1-866-SANDISK (726-3475)
7 days a week:
4am. - 10pm. Pacific Standard Time
7am - 1am Eastern Standard Time
[email protected]
I hope that helps
Please rate accordingly
Thank you
Computerrep
SOURCE: Cannot delete files from my mp3 player
open up my computer and go to the drive for your device (like mine is E: for my sansa E250, but yours may vary). just browse around the folders until you find where your music is stored and delete it from there.
