Question about Robitussin Cool Moisture 1 Gal. Humidifier
No problem need a price - Robitussin Cool Moisture 1 Gal. Humidifier
I have the HD15 how do you clean it latly everything is covered in a chalky mist in the room?
Hello FREIDA GRAYDEN,
If you are not TOTALLY SATISFIED... and that has
the SHARPER IMAGE price tag...
(in y opinion... I would return it to SHARPER IMAGE
and us the REFUND to buy 3 to 5 equivalent units ...
(like HoMedics) for a whole lot LESS...!!
(in my opinion)).
More units... less WATER spritzing around =
HAPPY FREIDA (I think).
I sincerely believe... the "chalky" you speak of is
merely a product of the CALCIUM level in your
water... and a mist type of humidifier. Nothing
wrong with your humidifier (follow owner manual
cleaning instructions) BUT what you see is normal
Sharper Image EV HD15 Instruction Manual Page 3
THE VISIBLE "mist" Your humidifier puts out are
solid water drops... It WILL mark whatever it
lands on...
I think there ARE things you could try...
Obviously turning down the humidifier to
merely moist... rather than SPRITZING water
on everything (solid/visible).
Spread the load between multiple machines
(as described above)
Perhaps...filtered water might help
Dietary CALCIUM is a very good thing... and humidity
is much more warm and comfortable... but the combination
is going to give you those SAME results...
But at those SHARPER IMAGE prices I would
expect YOU to be TOTALLY SATISFIED.
Carnac the Magnificent
https://www.amazon.com/HoMedics-Cool-Mist-Ultrasonic-Humidifier/dp/B00EW1QJPS/ref=pd_sbs_201_2?_encoding=UTF8&pd_rd_i=B00EW1QJPS&pd_rd_r=S79PF7TS0FVV4D24Y2GP&pd_rd_w=jrPo2&pd_rd_wg=POkzf&psc=1&refRID=S79PF7TS0FVV4D24Y2GP
Jan 11, 2018 | Humidifiers
How do I fix my blower problem on my humidifier?
Free Sears Humidifier User Manuals ' ManualsOnline.com
homeappliance.manualsonline.com > ... > Household Appliance Sears
Products 1 - 11 of 11 - Sears Humidifier 758.144120. Sears Kenmore Evaporative Console Humidifier Owner's Manual. Pages: 0 Saves: 0. See Prices
Oct 29, 2015 | Kenmore Quiet Comfort 12 Humidifier Filter...
I got E4 error message, and my tank is empty. The humidity value blink too... What can be the problem?
There is some type of electrical component that needs to be replaced called a relay switch. I had the exact problem and it was only a little over a year old. I am not impressed with the appliance for the price i paid for it. I went and bought the cheapest dehumidifier I could find and it works great. You can bypass this problem on your home comfort system by attaching the hose that came with it to the back and the machine will work the water will drain out of it. I
Apr 07, 2010 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Looking for filters for V3100
the filter that you need is a wf2. you can find that at target if you have one or a home depot. if not you can always go on ebay or amazon and they have them there. quoted price of about 14.99 per filter.
Aug 12, 2009 | Humidifiers
Need Replacement Tank for HWM-450 humidifier not under warranty
the website that you can go to to order is www.appliancefactoryparts.com. type in your model number, clickon a picture once it loads and then scroll down the page until you see water tanks. right now the price is 39.99
Feb 24, 2009 | Honeywell HWM-450 4 Gallon Humidifier
Aprilaire 440 won't stop running
Disconnect the two low voltage wirings going into the solenoid valve. If the water does not stop running after a few minutes the valve is bad. When you check your local area to price a new valve. Also get a price for a new humidifier. You will be surprised to find that a whole new unit isn't that much more. Or should I say that you will find that the replacement parts are overpriced.
Good Luck
HVAC Teacher
Feb 23, 2009 | Humidifiers
Fan not working
Use a PC computer case fan, they are cheap. ?
Apr 06, 2017 | Honeywell HUT-102 1.2 Gallon Humidifier
Cheap filters?
Check out TotalVac.com; Great prices!!!
Jan 10, 2009 | Bionaire BCM7204-U 3 Gallon Humidifier
Having trouble finding Undiluted white vinegar for cleaning
Hi dolphinblu...
Amazon offers pretty large number of articles (Undiluted white vinegar), click here Amazon com Undiluted white vinegar and pick one (who fits your needs, price etc..)
I hope this was helpful. enjoy
Nov 20, 2008 | Honeywell QuietCare HCM-630 Humidifier
Robitussin Cool Moisture 1 Gal. Humidifier Logo
Top Robitussin Humidifiers Experts
Paul Carew
Dennis
Marvin
Marvin
Are you a Robitussin Humidifier Expert? Answer questions, earn points and help others
