Question about Visioneer Office Equipment & Supplies
My roadwarrior 120 scanner wont install drivers i have windows 7 64
I cant get drivers to install software from visioneer says there installed but my computer does not recognize drivers
Posted by Travis Russom on
David Greene
    Master:
  • 663 Answers
Uninstall the drivers which are already in your computer and install a fresh version of it. Try going to the website of the manufacturer to find the driver and install it in your computer.
After doing that, update the drivers in your computer so that you can make sure that they'll work great. You can use RadarSync which you can get from here http://bit.ly/rsdriver
I hope this helps!
David
Posted on Apr 09, 2013
5 Related Answers
Beni S-P
arben pllana
  • 1006 Answers
SOURCE: Install Visioneer OneTouch 8920 Flatbed scanner
You need THOSE driver
Download
Rate me as FIXYA please
Posted on Jan 06, 2008
Anonymous
SOURCE: 8100 Visioner conflicts with Vista
Verified to work with Vista Home Premium x64 (should work for x32 as well):
1. Make sure your 8100 is unplugged.
2. Go to Visioneer's website and download drivers for the OneTouch 9420 scanner:
http://support.visioneer.com/products/home/9420/downloads_1.asp
3. Install the drivers. Nothing will work... yet, don't worry.
4. Now plug in your 8100. You'll get a message saying that Vista wants to find drivers. Select "Ask Me Later" or just cancel.
5. Next, open up Control Panel and then Device Manager. Find your 8100 in there (probably listed as "Unknown Device") and then right click on it and say "Update Driver Software". Now click "Browse My Computer For Driver Software" then "Let Me Pick From A List Of Device Drivers On My Computer".
6. Scroll down to "IMAGING DEVICES" then find Visioneer, then you should see the "Visioneer 9420" driver. Select it. You'll get a warning from Vista, but continue anyways. That's it... everything should work.
Posted on Mar 05, 2008
Clog2020
Chris Doty
  • 81 Answers
SOURCE: install visioneer onetouch 5600 scanner to windows xp
Go here:
http://support.visioneer.com/products/home/EOL/5600/downloads.asp
This has instructions and drivers for XP.
Posted on Apr 13, 2008
Anonymous
  • 4 Answers
SOURCE: Software to makE ONETOUCH VISIONEER 5800 scanner work with WINDOWS VISTA
You can go to Visioneer.com and order the disk. It is free but the shipping is $9.99.
Posted on Sep 03, 2008
Anonymous
  • 256 Answers
SOURCE: Mac wont recognize Mustek A3 1200 Scanner
If you have a photo editing program, see if it can connect to your photo scanner. Look under "File" and then "Import". If there is a "Twain" choice, that should be your scanner.
Posted on Jun 24, 2009
2helpful
Doesnt get connected under windows 7
For the Visioneer OneTouch 5600 Flatbed Scanner in windows 7 go to the visioneer web site at http://support.visioneer.com/products/5600/downloads.asp and download the file 5600.303110.EN.exe. Then right click on the file name and select Trouble shoot compatibility. Do not connect the scanner until told to. Run the program using the recommend settings. That installs the drivers. It does not install the paperport support software but does install the monitor in the task bar. That is enough to use the scanner and save or print the scans.
My scanner scans black Does not scan document.
Does the scanning light come on? The light may be burned out. Also Try cleaning the scanning tip.
Can I use my Visioneer 8920 with my new computer that has windows vista?
Yes you can use the Scanner with Vista O/, However you will not be able to use the same software or Icon like you did before in XP
Once you connect the Scanner to Vista O/S, it will install the pre-installed Drivers for this Scanner.
You will have to use Application programs to SCan like MS Paintbrush, or Windows Gallery or Microsoft Image Edition or PICASA etc.
Or you can also open Control panel and click on SCanners and Camera and double click on the Visioneer Scanner to use it.
Visioneer Scanner Drivers/Software for Vista are not yet available from the manufacturers so this is workaroud for you to use your scanner
3helpful
To install a Road Warrior scanner, do I need to totally uninstall my current all in one printer, scanner, copier?
No you dont.
However when you scan you would have to select the source as being either your AIO or the Roadwarrior. Not a big problem.
Some apps let you define the default in an individual type of way. so lets say you wanted to use the roadwarrior just for reciepts to OCR them into some planner or accounts package and use your AIO just for letters and larger forms then some apps will allow you to do that.
3helpful
2answers
Lost installation cd for visioneer 7600 scanner usb one touch
Hi! I have the correct driver for the Visioner 5300 / 7600 that will work with Windows XP and Vista. I can provide you a copy with complete instructions for installation. Please e-mail me at: [email protected]. Subj: 7600 driver.
1helpful
Visioneer 4400 usb scanner
here is my solution --uninstal the drivers form device manager unplug the power plug on back of scanner --go to visioneer website and get the xp driver for the 4400 scanner--save instead of running the download ---right click the downloaded installer and click compatable --make to run in xp mode and click OK--install the drivers as prompted when installed restart if prompted then plug the power back into the scanner----instal drivers as prompted --unfortunately --vista wont put the icon in my computer like xp does--the solution is to open program WINDOWS PHOTO GALLERY click file at top then import from scanner etc --the familiar page will come up with your scanner to preview or scan as you did before vista----this is the way i use it on vista home basic and i dont have any problems--hopefully you wont either
bill fae fife
1helpful
2answers
Visioneer OneTouch 5300 Flatbed Scanner
Hi ! I have a GOOD, Working driver for the Visioneer 5300 USB scanner, to work with Windows XP and Vista. I also include detailed install instructions. Send me an e-mail to [email protected] . Put in Subject Line - 5300 USB driver.
How to get one touch to install on xp
The Visioneer 7600 USB scanner is not supported on Windows XP, although it may function properly on most systems. If you choose to install the software on Windows XP, we recommend creating a system checkpoint by using the Windows XP System Restore feature. During installation Microsoft displays a warning dialog because the driver you are installing has not been submitted to Microsoft for testing. Click the Continue button to complete the installation. If you experience any problems with your scanner or operating system, remove the software and restore to the point created before you installed the driver.
Top Visioneer Office Equipment & Supplies Experts
Ekse
scramblepad
scramblepad
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
